  3. Landis E550 Time Ranged Load Profile Data
Profile picture for user Fatih
By Fatih , 19 June, 2021
Gurux.Net
I'm using an old version of GURUX .Net Lib (2017-2018). It's hard to upgrade to the latest version because of our currently project.
But I'm with tested your latest version of GURUX DLMS Director.
Hello! I'm trying to read Landis E550 Electrical Meter for Load Profile in time range. And DLMSDirector is working well.
So! With my code, even I define time range it still always reading whole data and it takes 10-15 minutes.
I have explained the problem in detail in the attached document. I'm stuck with this problem. I don't know what to do anymore. Can you help me, please? Thanks a lot.
Here is document link https://1drv.ms/b/s!AreQAoHJDLvziKZ8a2H4TDDeDCwuAQ?e=la4bGK
5 years 5 months ago
The best way to go is if you update to the latest version.
You don't need to set From and To. They are only to save current values if you change to a different profile generic in GXDLMSDirector.
r.From=start;r.To=end;
Check is capture objects empty. If it's empty all the data is read. You can read the capture object (attribute #2) or you can read the sort object.
I believe that because they are not read, the whole buffer is read.
Fatih
5 years 4 months ago
Hello. Thanks for the answer.
Hello. Thanks for the answer. Updating the Gurux libraries fixed it without any changes (in the sample code). In the main project these changes will be very difficult. Let's hope that other brand meter readings do not cause an error in the current project.
Thanks anyway.
