  3. Make Gurux.DLMS.cpp Client Example
make Gurux.DLMS.cpp Client Example
By Lotusv , 27 May, 2021
Tried to make Gurux.DLMS.cpp\GuruxDLMSClientExample
First the error appeared:
In file included from src/../include/../../development/include/GXDLMSSettings.h:41,
from src/../include/../../development/include/GXDLMS.h:42,
from src/../include/../../development/include/GXDLMSClient.h:38,
from src/../include/../../development/include/GXDLMSSecureClient.h:38,
from src/../include/communication.h:68,
from src/communication.cpp:35:
src/../include/../../development/include/GXPlcSettings.h:40:10: fatal error: GXByteBuffer.h: No such file or directory
#include "GXByteBuffer.h"
In folder /development/include/folder contains only the GXBytebuffer.h file. I copied it to GXByteBuffer.h. Because the code also needs a file with a small "b".
An error occurred during assembly:
src/communication.cpp: In member function ‘int CGXCommunication::Open(const char*, int)’:
src/communication.cpp:588:13: error: ‘iec’ was not declared in this scope
if (iec)
make: *** [makefile:31: obj/communication.o] Error 1
I have not been able to make project. How do I fix the error?
5 years ago
Thank you for pointing this out. I made an issue from this and this is now in testing.
https://www.gurux.fi/node/18509
Change this line:
if (iec)
to
if (m_Parser->GetInterfaceType() == DLMS_INTERFACE_TYPE_HDLC_WITH_MODE_E)
The new version is released today.
Lotusv
5 years ago
Thanks for the answer.
OK. I'll download the new version, check it out tomorrow!
Lotusv
5 years ago
The previous errors
The previous errors disappeared, the following appeared:
/usr/bin/ld: cannot find -lgurux_dlms_cpp
collect2: error: ld returned 1 exit status
make: *** [makefile:27: bin/gurux.dlms.client.bin] Error 1
Lotusv
5 years ago
I solved the problem.
https://www.gurux.fi/comment/11416#comment-11416
I went back and build the development project first , then resumed the server example build , and this time linker found it
Thanks, Mr Kurumi!
