  3. Access Error: Device Reports Read-Write Denied With Ivy Meters
Access Error: Device reports Read-Write denied with Ivy meters
By Vasyl , 26 May, 2021
Good afternoon, Mr. Kurumi.
I have some difficulty using the gurux library. I have a meter from Ivy Metering Co., Ltd. The meter has a GPRS module, in which a card with a static ip address is installed. I have certain configurations from the manufacturer:
- ClientAddress = 10;
- Server Address = 10;
- Authentication.Low
- Password
From the start I tried to use Gurux DLMS Director with these configurations but got the following "Connection refused" error.
Then I decided to use Gurux.DLMS.Meter.Listener.Net, specifying all the parameters, I started receiving push notifications from meter and found that it sends other ClientAddress and ServerAddress values, they were equal to 1. Then I tried to replace the current value of 10 with 1 and it turned out to be authenticated. And get the following values:
Client is connected.
Send AARQ request
TX: 15:52:43 00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 33 34 35 36 37 38 39 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D 04 B0
RX: 15:52:44 00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 00 F8 00 07
Parsing AARE reply61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 00 F8 00 07
Parsing AARE reply succeeded.
TX: 15:52:44 00 01 00 01 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
RX: 15:52:45 00 01 00 01 00 01 00 05 C4 01 C1 01 03
Disconnecting from the meter.
TX: 15:52:45 00 01 00 01 00 01 00 17 62 15 80 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D 00 F8
RX: 15:52:46 00 01 00 01 00 01 00 02 63 00
Access Error: Device reports Read-Write denied.
after that I got stuck, I tried different parameters but only with these "GXDLMSClient (true, 1, 1, Enums.Authentication.Low," 13456789 ", Enums.InterfaceType.WRAPPER)" I was able to get authenticated. If you have any idea why I am getting this "Access Error: Device reports Read-Write denied." I'll be very grateful.
5 years 3 months ago
Change your client and server address like this:
GXDLMSClient (true, 10, 10, Enums.Authentication.Low,"13456789", Enums.InterfaceType.WRAPPER);
I don't know are the client and server addresses in hex format, but I believe that your client address is wrong.
Vasyl
Thanks for the quick answer,
Thanks for the quick answer, I have already tried connecting with such parameters and the answer was as follows:
Send AARQ request
TX: 18:25:44 00 01 00 0A 00 0A 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 33 34 35 36 37 38 39 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
RX: 18:25:45 00 01 00 01 00 01 00 2B
Source addresses do not match. It is 1. It should be 10.
Can you connect with the public client? Like this:
GXDLMSClient (true, 0x10, 0x1, Enums.Authentication.None, null, Enums.InterfaceType.WRAPPER);
Vasyl
i tried your configs and got
i tried your configs and got the following response.
Send AARQ request
TX: 10:31:29 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
RX: 10:31:30 00 01 00 01 00 01 00 21
Destination addresses do not match. It is 1. It should be 16.
Vasyl
I tried different
I tried different configurations, but as I wrote above, I achieved the greatest result with these parameters.
GXDLMSClient(true, 0x01, 0x01, Enums.Authentication.Low, "13456789",Enums.InterfaceType.WRAPPER)
but i catch this error
so i think clientAddress and serverAddress is right, how i understand this error can be only if we pass authentication, right?
It might be that they haven't implemented the association view. Can you try to add the clock object manually?
Use original settings. Then select "Add Object" from "Edit" menu. Select Clock and set 0.0.1.0.0.255 to logical name. Establish the connection and try to read the clock object. If you can read it you need to ask the list of objects that the meter implements.
Vasyl
at the current stage I was
at the current stage I was able to advance only when I used Gurux.DLMS.Meter.Listener.Net
when i use GXDLMSDirector, i cant even connect to the meter, i use almost the same parametrs like in GXDLMSClient(true, 0x01, 0x01, Enums.Authentication.Low, "13456789",Enums.InterfaceType.WRAPPER)
when host is open, i try to connect with GXDLMSDirector, but then i got next message "the destination computer rejected the connection request"
Vasyl
Thats why i cant recieve only
Thats why i cant recieve only Clock parametr
Vasyl
these are the standards that
these are the standards that my meter supports
The server (or client) address might be different when the connection is established to the meter (GXDLMSDirector) or when the meter establishes the connection to the server (Gurux.DLMS.Meter.Listener.Net).
You need to use a different server address when you connect to the meter with GXDLMSDirector. Server and client addresses are not defined in standards. You need to ask the meter manufacturer what values you need to use.
