  3. Arduino Decryption
Arduino decryption
By greenMike , 27 April, 2021
Hello, is there an example code to read out a smart meter for Lower Austria EVN (Netz Niederösterreich) based on an arduino? Is the decryption also available for the Arduino.
Under Phyton and a raspberry I managed to do it now with an Arduino.
I want to process everything on the Arduino and output it via a web interface or save it on an SD card.
Mike
5 years 6 months ago
You can do it with the Arduino example. You need to change the client and server address and then set ciphering settings. I can show what you need to do If you post python settings here.
greenMike
Can I send you the Python program privately? To which email address?
However, it is not a normal Mbus interface; it is only an output of the data.
BR
Mike
You want only to receive incoming push messages from the meter and you don't want to read anything from the meter?
greenMike
The smart meter gives me the data every 5 seconds and I want to read and decrypt them with an Arduino.
I cannot transmit any data or commands to the smart meter.
The data line is an RJ-10 connector with Mbus + and Mbus-.
BR
Mike
OK. Then you don't do anything with the client example. You need push example and it's not implemented for Arduino at the moment.
https://github.com/Gurux/GuruxDLMS.c/tree/master/GuruxDLMSPushExample
It's not hard to implement, but it will take some time before we can implement it.
I'll add it to the worklist. Ask again after next week if I haven't replied to this.
greenMike
thanks for the quick reply you could also post an example on github. And I'll get back to you next week. Have a nice day at work.
Mike
greenMike
5 years 5 months ago
I just wanted to remind her briefly.
Mike
Tests are in progress. I believe it's released today.
greenMike
thanks for the answer you don't need to stress yourself unnecessarily if it is not finished today. If it is finished this week or next week, it is completely sufficient.
Mike
Push listener is released for Arduino.
https://github.com/Gurux/GuruxDLMS.c/tree/master/Arduino_IDE/pushListen…
It listens push messages from one serial port and prints content of the push message to another serial port.
Note! You need to define what kind of data the meter is sending. You can get this information if you can read push object list from the Push object.
greenMike
4 years 10 months ago
Hello, can you check my data.
Hello, can you check my data. Please
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
Key
D833BE8602D029CEA517867835550816
The meter is a Kaifa MA309
I can decrypt the data but unfortunately I cannot translate it.
Your meter is sending a wired M-Bus message, but all the data can't fit into one frame. You need to send a few messages that the meter is sending so it's possible to parse the data.
greenMike
Thank you for your prompt
Thank you for your prompt reply.
I have the network operator EVN and this company offers two meters, the Sagemcom three-phase energy meter T210-D and the Kaifa three-phase energy meter MA309.
I can decrypt and translate the data from the T210-D but not the one from the Kaifa. Are they using a different protocol?
https://www.netz-noe.at/Download-(1)/Smart-Meter/218_9_SmartMeter_Kunde…
That is the documentation and there is no difference made.
It seems that both are using DLMS, but the framing is different. Kaifa is using M-Bus framing and Sagemcom HDLC. You should parse both if you change the InterfaceType. In default it's HDLC.
greenMike
I program in python and use
I program in python and use this funktion. Can I transfer parameters for Mbus framing?
tr = GXDLMSTranslator()
tr.pduToXml(pdu_from_the_meter)
Is it possible to select this MBUS framing in the desktop version of the Gurux DLMS Director?
Greetings and thank you for your work
Yes, you can select MBusWired for GXDLMSDirector. I notest that Mbus framing for Python is not released as an open-source. It's released later this week.
greenMike
I tried it but unfortunately
I tried it but unfortunately I always get Invalid data type.
Krypted Data:
Dekryptedt:
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
Gurux DLMS Translater: Interface WiredMBus Show messages: All Follow messages:None
greenMike
Krypted Data:
Dekryptedt:
There are two frames in your data. you need to find them with FindNextFrame and convert using MessageToXml, not PduToXml method.
Decrypted data is below.
<DataNotification>
# High priority.
# Invoke ID: 3940889
<LongInvokeIdAndPriority Value="803C2219" />
# 20.12.2021 20.56.55
<DateTime Value="07E50C140113383700FFC400" />
<NotificationBody>
<DataValue>
<Structure Qty="23" >
# 20.12.2021 19.56.55+01:00
<OctetString Value="07E50C140113383700FFC400" />
# 1.0.1.8.0.255
<OctetString Value="0100010800FF" />
<UInt32 Value="0025C73A" />
<Structure Qty="02" >
<Int8 Value="00" />
<Enum Value="1E" />
</Structure>
# 1.0.2.8.0.255
<OctetString Value="0100020800FF" />
<UInt32 Value="001AEA2B" />
<Int8 Value="00" />
<Enum Value="1E" />
</Structure>
# 1.0.1.7.0.255
<OctetString Value="0100010700FF" />
<UInt32 Value="0000023F" />
<Int8 Value="00" />
<Enum Value="1B" />
</Structure>
# 1.0.2.7.0.255
<OctetString Value="0100020700FF" />
<UInt32 Value="00000000" />
<Int8 Value="00" />
<Enum Value="1B" />
</Structure>
# 1.0.32.7.0.255
<OctetString Value="0100200700FF" />
<UInt16 Value="08FB" />
<Int8 Value="FFFFFFFFFFFFFFFF" />
<Enum Value="23" />
</Structure>
# 1.0.52.7.0.255
<OctetString Value="0100340700FF" />
<UInt16 Value="08F8" />
<Enum Value="23" />
</Structure>
# 1.0.72.7.0.255
<OctetString Value="0100480700FF" />
<UInt16 Value="08FF" />
<Enum Value="23" />
</Structure>
# 1.0.31.7.0.255
<OctetString Value="01001F0700FF" />
<UInt16 Value="00C0" />
<Int8 Value="FFFFFFFFFFFFFFFE" />
<Enum Value="21" />
</Structure>
# 1.0.51.7.0.255
<OctetString Value="0100330700FF" />
<UInt16 Value="0032" />
<Enum Value="21" />
</Structure>
# 1.0.71.7.0.255
<OctetString Value="0100470700FF" />
<UInt16 Value="00B1" />
<Enum Value="21" />
</Structure>
# 1.0.13.7.0.255
<OctetString Value="01000D0700FF" />
<UInt16 Value="02C2" />
<Int8 Value="FFFFFFFFFFFFFFFD" />
<Enum Value="FF" />
</Structure>
# 181210098551
<OctetString Value="313831323130303938353531" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
greenMike
I tried it but unfortunately it doesn't work. I also looked at the function on github but I don't understand which parameters are what.
def findNextFrame (self, data, pdu):
as which parameter do I have to transfer my decrypted data?
and what do I get back just a number with the length where the next message begins?
and whicht datatype is needed for the return ?
As I told you before the open-source version from MBus is not released for Python. It's released later today.
Get the latest version.
You can use it like this:
translator = GXDLMSTranslator()
translator.blockCipherKey = GXByteBuffer("D833BE8602D029CEA517867835550816")
translator.comments = True
pdu_from_the_meter = "68fafa6853ff000167db084b464d65509a177781f820000c41712749cc29f568b4b44f7f0b62cd71325da2a0415219ffc3c7b15b8f30270840031afe7e96f9d9873de4ab83b95254477fac2f87ff3fb472cf9400dffb07a755b958fcfd81bf41054f23a6bec9cf5256645862856adc05331ac49c761e43a6992ba07eff07e06b400e00c7e4faca9a98c718c6ab024b1871a5cc09317714202fb05172324252952aec417aee676e1954946d7ec06b74ba3831d827b91f38db3f3637faa8395c6478c12bc0c2a223de0708c647c423017226fdf5ebb85c6d3877044d223e71913fd7a05a7ac737da0cc705b70b4d3b08096bbe77042a98380873f778ac92fe9e166814146853ff1101674a49eebd9694f8cbf47e536ca2fafec116"
msg = GXDLMSTranslatorMessage()
msg.message = GXByteBuffer(pdu_from_the_meter)
xml = ""
pdu = GXByteBuffer()
translator.completePdu = True
while translator.findNextFrame(msg, pdu):
pdu.clear()
xml += translator.messageToXml(msg)
if msg.moreData == RequestTypes.NONE:
break
greenMike
Hello i try it but it doesnt
Hello i try it but it doesnt work
my imports
from gurux_dlms.GXByteBuffer import GXByteBuffer
from gurux_dlms.GXDLMSTranslator import GXDLMSTranslator
import gurux_dlms
This is the issue
File "c:\Users\admin\Desktop\Python Programme\Mining\SmartMeterKaifa.py", line 9, in <module>
File "C:\Users\admin\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\__init__.py", line 47, in <module>
from .GXDLMS import GXDLMS
File "C:\Users\admin\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\GXDLMS.py", line 68, in <module>
from .plc.enums import PlcDataLinkData, PlcHdlcSourceAddress, PlcMacSubframes, PlcSourceAddress, PlcDestinationAddress
ModuleNotFoundError: No module named 'gurux_dlms.plc
and that is not recognized in the IDE as if it is not present
The Version is correct i think
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: gurux_dlms in ./.local/lib/python2.7/site-packages (1.0.116)
plc folder was empty and it was removed on deployment. This is now fixed. Update to the latest version.
greenMike
Hello
Hello
thank you i solve all problems
BR Michael
Hello Michael,
Hello Michael,
Thanks for letting me know.
Norbert
4 years 6 months ago
Hello
Hello
is the result of this discussion, a code snippet, available on Github?
Want to do the same with ESP32: EVN smartmeter, one Kaifa and one Sagemcom... notification ever 5 seconds.
Norbert
In reply to Hello by Norbert
Hi Norbert,
Hi Norbert,
preslmayer
Hi Mikko. Can you please tell
Hi Mikko. Can you please tell me how the python code from post #25 works in Java?
It is not working for me. I used the same data which is used in post #25.
It get the following Exception in method findNextFrame:
Exception in thread "main" java.lang.IllegalArgumentException: getUInt16
at gurux.dlms.GXByteBuffer.getUInt16(GXByteBuffer.java:377)
at gurux.dlms.GXDLMSTranslator.findNextFrame(GXDLMSTranslator.java:449)
thank you.
Java doesn't support Wired MBus at the moment. I'll add it to the worklist and it's coming for the next release.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
