  2. Generating Custom Certificates With OpenSSL
Public-key cryptography
Generating custom certificates with OpenSSL
You can generate DLMS certificates with OpenSSL. It's important that certificates are saved in correct format because DLMS standard defines only PKCS 8, PKCS 10 and x509 Certificate formats.
Convert pfx to PEM format
If the certificates are in pfx format they can convert to pem using openssl like this:
openssl pkcs12 -in YOUR_CERTIFICATE.pfx -nocerts -nodes
-out YOUR_CERTIFICATE.pem
Printing the certificates in readable format
PKCS 8 Private key.
openssl ec -in rootCA.pem -text -noout
PKCS 10 certificate certificate request.
openssl req -in client1.csr -text --noout
x509 certificate
openssl x509 -in guruxCA.pem -text
Create root CA
You can make custom certificates by yourself. First you need to create an Root CA. Root CA is used to sign your custom certificates.
For that you need to create ca.ext file where you define key usage and other settings.
Content of ca.ext file:
authorityKeyIdentifier=keyid,issuer
basicConstraints=critical, CA:TRUE
keyUsage=critical, keyCertSign, cRLSign
Create Root CA private Key.
openssl ecparam -out rootCA.key -name prime256v1 -genkey
Or for P384
openssl ecparam -out rootCA.key -name secp384r1 -genkey
Create custom Root CA certificate:
openssl req -new -nodes -key rootCA.key> rootCA.csr
You must apply CA settings something like:
You are about to be asked to enter information that will be incorporated
into your certificate request.
What you are about to enter is what is called a Distinguished Name or a DN.
There are quite a few fields but you can leave some blank
For some fields there will be a default value,
If you enter '.', the field will be left blank.
Country Name (2 letter code) [AU]:FI
State or Province Name (full name) [Some-State]:Pirkanmaa
Locality Name (eg, city) []:Tampere
Organization Name (eg, company) [Internet Widgits Pty Ltd]:Gurux Security
Organizational Unit Name (eg, section) []:Gurux
Common Name (e.g. server FQDN or YOUR name) []:Root CA 256
Email Address []:
Please enter the following 'extra' attributes
to be sent with your certificate request
A challenge password []:
An optional company name []:Gurux.Ltd
Self sign Root CA certificate:
openssl x509 -extfile ca.ext -in rootCA.csr -out rootCA.crt -req -signkey rootCA.key -days 1001
Create certificate for the client
First you need to create cl.ext file where you define key usage.
Content of cl.ext file for the digitalSignature:
keyUsage=critical,digitalSignature
Content of cl.ext file for the keyAgreement:
keyUsage=critical,keyAgreement
Generate an ECDSA private Key. There is own private key for each client.
openssl ecparam -out client1pk.key -name prime256v1 -genkey
Or for P384
openssl ecparam -out client1pk.key -name secp384r1 -genkey
You can print the private and public key in textual format:
openssl ec -in client1pk.key -text -noout
Save private key in PKCS 8 Format. This is important because DLMS standard uses only PKCS formatted keys.
openssl pkcs8 -topk8 -outform PEM -in client1pk.key -out client1pk.pem -nocrypt
Generate client application or meter certificate request. Common Name must be the same as the system title.
openssl req -new -key client1pk.key -nodes> client1cert.csr
You must apply client settings something like:
Organization Name (eg, company) [Internet Widgits Pty Ltd]:Gurux Ltd
Common Name (e.g. server FQDN or YOUR name) []:'4758436C69656E74'
Email Address []:
An optional company name []:Gurux Ltd
openssl x509 -extfile cl.ext -in client1cert.csr -out client1.pem -req -CA rootCA.crt -CAkey rootCA.key -CAcreateserial -days 1001
You can print the content of the x509 file in textual format:
openssl x509 -in client1.pem -text
You can generate meter certificate in the same way you generated the client certificate. The only difference is to change Common name to meter system title.
