  2. Few Bugs Found In GuruxDLMS.c For Arduino
Few bugs found in GuruxDLMS.c for Arduino
By Jeroen88 , 10 April, 2021
I found a few bugs in the GuruxDLMS.c library:
In gxsetmalloc.c at https://github.com/Gurux/GuruxDLMS.c/blob/4589a382593d5e6911586850fb2c7…
if (ret != DLMS_ERROR_CODE_UNAVAILABLE_OBJECT)
should be (I think)
if (ret == DLMS_ERROR_CODE_OK)
because cosem_createObject(class_id, &object) can also return other error codes. I am also surprised that this function gets executed (while retrieving the object list) because I am using SN and this line is part of the function cosem_parseLNObjects(dlmsSettings* settings, gxByteBuffer* data, objectArray* objects).
In helpers.c at https://github.com/Gurux/GuruxDLMS.c/blob/4589a382593d5e6911586850fb2c7…
#if defined(_WIN32) || defined(_WIN64) || defined(__linux__)
I changed it into
#if defined(_WIN32) || defined(_WIN64) || defined(__linux__) || defined(ESP32)
because I use that MCU
In variant.c at https://github.com/Gurux/GuruxDLMS.c/blob/4589a382593d5e6911586850fb2c7…
hlp_int64ToString(buff, 250, tmp.uiVal, 1)
should be
hlp_int64ToString(buff, 250, tmp.llVal, 1)
Best Jeroen
5 years 3 months ago
Hi Jeroen,
Hi Jeroen,
Thank you for the hlp_int64ToString and cosem_createObject information. That is now updated.
If your meter is using a short name referencing cosem_parseSNObjects is called and not the cosem_parseSNObjects. Make sure that you haven't made any changes to the source code.
Jeroen88
So say "If your meter is using a short name referencing cosem_parseSNObjects is called and not the cosem_parseSNObjects. Make sure that you haven't made any changes to the source code."
I do not understand your answer (because you say cosem_parseSNObjects twice)
The meter is using SN, but the (unmodified) code calls cosem_parseLNObjects, so the parsing for Logical Names. That surprises me, but maybe it is correct.
Sorry, it's a typo. If your meter is using short name referencing it's calling cosem_parseSNObjects.
cosem_parseLNObjects is called when logical name referencing is used.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
