  2. CTT Test Failed
CTT test failed
By Ashok_Chowdary , 19 February, 2021
I just run the CTT test which is on GURUX Client. it gave report with lot of failed conditions.
please help me where is the wrong. i am using gurux library C stack only.
here the report,
Starting to execute test for US.
Starting HDLC tests #1.
Passed.
Starting HDLC tests #2.
Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc2">Test #2 failed.</a>Starting HDLC tests #3.
Ignored.
Starting HDLC tests #4.
HDLC Illecal frame test (Opening flag missing).
HDLC Illecal frame test (Closing flag missing).
HDLC Test #4. Closing flag missing failed.HDLC Test #4. HDLC Illecal frame test (Both flags are missing).
Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc4">Test #4 failed.</a>Starting HDLC tests #5.
SNRM request failed. Media is closed.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc5">Test #5 failed.</a>Starting HDLC tests #6.
Disconnect request failed. Media is closed.SNRM request failed. Media is closed.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc6">Test #6 failed.</a>Starting HDLC tests #7.
Disconnect request failed. Media is closed.Disconnect request failed. Media is closed.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc7">Test #7 failed.</a>Starting HDLC tests #8.
Disconnect request failed. Media is closed.Disconnect request failed. Media is closed.Disconnect request failed. Media is closed.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc8">Test #8 failed.</a>Starting HDLC tests #9.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc9">Test #9 failed.</a>Starting HDLC tests #10.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc10">Test #10 failed.</a>Starting HDLC tests #11.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc11">Test #11 failed.</a>Starting HDLC tests #12.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc12">Test #12 failed.</a>Starting HDLC tests #13.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc13">Test #13 failed.</a>Starting HDLC tests #14.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc14">Test #14 failed.</a>Starting HDLC tests #15.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc15">Test #15 failed.</a>Starting HDLC tests #16.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc16">Test #16 failed.</a>Starting HDLC tests #17.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc17">Test #17 failed.</a>Starting HDLC tests #18.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc18">Test #18 failed.</a>Starting HDLC tests #19.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc19">Test #19 failed.</a>Starting HDLC tests #20.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc20">Test 20 failed.</a>Starting HDLC tests #21.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc21">Test 21 failed.</a>Starting HDLC tests #101.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc101">Test #101 failed.</a>Failed to receive reply from the device in given time.
5 years 5 months ago
There is an error in the current tests. We added a re-send count for the CCT tests and that is causing those tests will fail. This is fixed to the next release from GXDLMSDirector. ANSI C stack works as expected.
  • Thomasqto
  • Uka Ibe
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
