  3. C# - Specify Max Payload Size and Window Size In SNMR Trace
C# - Specify Max payload size and Window size in SNMR trace
By dfranco_ , 4 January, 2021
Hello and happy new year,
When sending the SNRM trace using GXDLMSDirector it works and the communication with the meter is perfect. But in the C# library, we are not able to send it with the following configuration:
* Max payload size in transmit = 228
* Max payload size in receive = 228
* Window size in transmit = 1
* Window size in receive = 1
So we end up sending this:
<HDLC len="12" >
<TargetAddress Value="32767" />
<SourceAddress Value="2" />
<!--SNRM frame.-->
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
Instead of this:
<HDLC len="32" >
<!--SNRM frame.-->
<PDU>
<Snrm>
<MaxInfoTX Value="228" />
<MaxInfoRX Value="228" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Snrm>
</PDU>
</HDLC>
We are defining the GXDLMSClient as, but it doesn't seem to be a way to define the max payload size values and the window size bytes don't build up in the trace:
client = new GXDLMSClient
InterfaceType = InterfaceType.HDLC, Authentication = Authentication.Low,
WindowSize = 0x01,
InvokeID = 0x01,
Password = password, ServerAddress = clientAddress, ServerAddressSize = 0x0004,
ProposedConformance = ...
Is it possible to define these parameters in the GXDLMSClient ?. Could you help us pointing us how to specify the max payload size values?
Respectfully,
5 years 7 months ago
You can change those values from GXDLMSClient.HdlcSettings.
dfranco_
5 years 6 months ago
Thanks for your reply Mikko,
I managed to get a longer SNMR with MaxInfoTX, MaxInfoRX, WindowSizeTX and WindowSizeTX trace by forcing parameters but the parameters are not accessible to be changed.
Within the class GXDLMSClient of the the C# library we do find GXDLMSClient.HdlcSettings, also, we do have the class GXHdlcSettings, which contains the attributes MaxInfoTX, MaxInfoRX, WindowSizeTX and WindowSizeTX but it is not allowed to modify as you see, it has only the GET option:
public GXHdlcSettings HdlcSettings { get; }
And therefore we get default 128 value for MaxInfoRX and MaxInfoTX:
<HDLC len="32" >
<!--SNRM frame.-->
<PDU>
<Snrm>
<MaxInfoTX Value="128" />
<MaxInfoRX Value="128" />
</Snrm>
</PDU>
</HDLC>
In the end is it not possible to modify MaxInfoRX and MaxInfoTX to the value of 228? Is it a feature that you may foresee coming in further versions?
Kind regards
Hi Daniel,
Hi Daniel,
You can modify values like this:
GXDLMSClient client = new GXDLMSClient();
client.HdlcSettings.MaxInfoTX = 228;
client.HdlcSettings.MaxInfoRX = 228;
dfranco_
Thank you very much Mikko.
Thank you very much Mikko. The SNMR worked fine.
  • liha_2019
  • FiqJXzPfbTtORWoZ
  • Georgegeowl
  • brsRKNujhfnXWm…
