  3. LLS_password Change In US Association
LLS_password change in US association
By Ashok_Chowdary , 10 December, 2020
How we can change MR association password and Firmware Association password in US Association.
please help me.
5 years 11 months ago
If you can see several associations when connecting using US, select the association (MR or Firmware) and change the password.
If you cna't see the associations, you need to connect to the meter using MR and Firmware authentication. Then you can change the authentication password for the connected association. With some meters, there is its own password for each association. This causes that you need to connect to that association to change the password. If your meter is using the same password for all the associations, you should be able to change the Firmware password if you connect with US and change the password.
