  2. Not Able To Add The Object In Load Profile
Not able to add the Object in Load Profile
By husainmalkani@… , 3 December, 2020
I am trying to add the Object in the load profile, but after 11 objects added to the load profile, it is not allowing me to add any 12th object. by default, there are 6 objects in the Load profile. also, there is no logic in restricting the number of objects that can be added.
Here is the log of the 11th Object added:
GXDLMSDirector 8.2.2011.1101
Log created 10:42:24
10:42:35 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A8 89 03 C9 78 87 A6 E6 E6 00 C9 81 E6 30 00 00 02 81 AD 39 8A 62 90 CC C7 77 68 21 E5 C6 F7 CF 94 5A AD 96 A9 96 65 B1 92 47 9A 45 88 10 12 9E 2D E3 CD 86 3A BA DA 1C DB 18 AC 08 65 B5 9E 70 55 A7 77 C9 2A 96 6E 53 98 52 4F C0 7F 11 F6 ED 81 C9 AD 65 47 6C 25 4B B7 87 89 A7 BF EA 0F 37 09 4C 6A D9 2F 69 E4 CB E5 F8 87 E2 5F 88 42 DF 98 C3 4B 92 49 84 47 F7 B6 7A 4A 0B 2C BC AC A2 39 10 D6 54 BD 53 B6 20 65 7E
10:42:35
7E A0 07 C9 03 B1 7C 6A 7E
7E A0 75 03 C9 7A AA 3F D8 74 72 E6 74 4E 7E C3 C3 5B 87 8A 2B 4F C8 8B 66 BE 0A 58 3F 30 16 C3 A7 A8 27 2A 30 C8 1B 5A 4A 55 80 31 57 CF 6D 19 7E 5B 0E B7 43 3F 35 F1 32 22 C8 C4 D2 D1 78 8D 35 72 0D 88 96 88 91 16 54 F5 F9 3C 70 91 36 AB 3D 74 9B F6 2E 9B 46 C5 56 CF 00 B2 21 E3 84 27 7E 83 1F 21 30 47 AD A0 47 3E 51 90 47 DE 63 52 FA 37 5B A7 8D A7 7E
10:42:35
7E A0 23 C9 03 D6 7A 80 E6 E7 00 CD 15 30 00 00 02 80 E8 39 90 5A 58 84 9F D4 DF 5A 6B 71 49 ED 74 AD D8 BE 7E
10:42:35 Reading object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 2C 03 C9 9C E7 91 E6 E6 00 C8 1E 30 00 00 02 82 4E 19 FA B2 98 78 A4 35 23 72 06 41 EA 46 CD 21 35 C0 BF 70 73 8F F8 E9 0D D6 F8 7E
10:42:36
7E A8 89 C9 03 F8 B5 6C E6 E7 00 CC 81 DD 30 00 00 02 81 A8 39 8A 62 96 C6 C5 10 7B 21 12 CC F1 CE 9F 59 A9 84 56 91 6E A5 92 47 99 41 9A EF 1C 95 39 E3 CD E4 34 A9 25 12 D0 0C AC 08 07 BB 8D 8F 59 AC 63 C8 2A 81 62 41 67 5E 44 D4 7E 11 E1 E1 93 36 A1 6E 53 6D 25 60 BB 95 76 AB B4 FE 0E 37 22 40 78 26 23 62 F0 CA E5 C7 8B F0 A0 84 49 CB 99 C3 74 9E 5B 7B 4B FC A2 7B 4A 08 20 AE 53 AE 32 04 D7 54 BE 5F A4 B7 F7 7E
10:42:36 Get next frame.
10:42:36 Reading object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 07 03 C9 B1 46 24 7E
10:42:36
7E A0 6C C9 03 FA 5A CF 27 78 79 F2 75 4E 56 CF D1 A4 8B 81 3F 4E C8 A3 6A AC F5 54 34 24 17 C3 9B A4 35 D5 3C C3 0F 5B 4A 55 8C 23 A8 C3 66 0D 7F 5B 0E BB 51 C0 39 FA 26 23 C8 C5 DE C3 87 81 3E 66 0C 88 97 84 83 E9 58 FE ED 3D 70 97 3A B9 C2 78 90 E2 2F 9B 40 C9 44 30 0C B9 35 E2 84 30 A8 66 E4 79 2E E6 41 FD FC B7 F5 8D D1 7E
Here is the log of the 12th Object added:
Log created 10:31:00
10:31:13 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A8 89 03 C9 BA 99 43 E6 E6 00 C9 81 F8 30 00 00 02 5C B8 16 B2 09 4B 30 49 2F 01 21 DB BD F3 B2 D0 E8 9B 8D D6 D8 C3 A0 99 BD D7 A3 6E 46 28 6F C3 91 D4 C7 19 12 68 CB A0 92 90 8D 66 CF 2F 68 63 6A DF 91 B7 B2 7E A0 2D 37 E0 15 91 41 F3 5E 60 29 95 CC 22 C5 4D 53 91 CA EA A6 A1 C2 E9 7D 4B 62 05 DF E8 3E 00 F1 97 44 28 74 EE D4 36 DB FF 00 AD 42 9B FF C2 F8 76 E2 E8 85 CF D2 FB 0E 1F 14 A0 18 44 0E ED 2B F4 7E
10:31:13
7E A0 07 C9 03 D1 7A 09 7E
7E A0 85 03 C9 BC BB EB AE 8D 6B CA D3 B3 22 77 D7 79 C8 F0 7D 4D F6 95 E0 08 FF E0 33 3D 4B 56 35 6C A1 3E CC EF FC F3 54 C7 3A 71 21 1C BB 94 80 09 15 3C FB BF F0 78 AA 41 E6 75 AE 67 E0 AC 9F 40 12 6F 9C 11 32 05 6C 89 07 59 7E C4 8E DF 5C A9 BE 62 F7 1C 0B B0 82 F0 89 4D 9F 76 49 15 85 57 C5 AD 86 14 64 5B C2 65 EA 03 69 02 A5 6D 15 27 B5 90 FC 8F 69 A3 CC 93 6B EA 5D C6 1F D9 CD 97 AE 20 39 1C 7E
10:31:14
7E A0 23 C9 03 FA 14 6B E6 E7 00 CD 15 30 00 00 02 5B D1 0B 86 EE 39 AF A9 A3 7D 6B 3F 80 9D EB 1B 43 56 49 7E
10:31:14 Writing object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 24 03 C9 DE 29 15 E6 E6 00 C9 16 30 00 00 02 5D 88 D7 F7 A2 65 F0 CA 92 C6 6F B6 DA F6 DC FD EA 3F FA 49 7E
10:31:14
7E A0 23 C9 03 1C 2C E9 E6 E7 00 CD 15 30 00 00 02 5C BC 16 B2 0D 43 4B A9 98 9B D1 4D A8 60 B8 D7 80 4A 70 7E
Gurux.DLMS.GXDLMSException: Access Error : Device reports a undefined object.
at GXDLMSDirector.GXDLMSCommunicator.Write(GXDLMSObject obj, Int32 index)
at GXDLMSDirector.MainForm.WriteMnu_Click(Object sender, EventArgs e)
Here the thing is, the same object is added as the 11th object and added successfully, but if it is added as the 12th object, the error is coming: "Access Error: Device reports an undefined object."
5 years 6 months ago
I believe that the reason for this is that your meter allows adding only 11 objects. You need to verify this from the meter vendor. DLMS standard doesn't define the maximum amount of objects and it's vary between the meters.
husainmalkani@…
I am testing a custom meter,
I am testing a custom meter, and according to its specification, it can allow a maximum of 16 objects. there are two load profiles. in Load profile 1, I am able to add 11 objects and in load profile 2 only 10 objects can be added. but as per the specification of the custom meter, it should allow me to add 16 objects in both the load profiles.
This is not the first time when the specification and implementation don't match. :-)
I can't check the bytes because your data is ciphered and I don't know the keys.
Select "View" | "Trace" and "XML". Then add XML from the trace view here.
But this looks that you can capture only 11 objects.
husainmalkani@…
11:28:16
11:28:16
<HDLC len="88" >
<TargetAddress Value="1" />
<SourceAddress Value="64" />
<FrameType Value="9C" />
<NextFrame Value="C981F8300000026A2DE2FECDAE5FF9CF9906CDF861138D214B9782B54BDA2E70C2A0B1AF6EDFA83421864877BF1BC16AB949B46B61813DDC5E4F6993A68C75D6B8586B818B5EAC8F2B86D26D824DDDFA603DF2DF6E1BBEA243728F4ADD2147B1AECD2B0BEEA4EBC396DEF10A5F77830735613B6C46C2B38A32FE14B8EE" />
</HDLC>
11:28:16
<HDLC len="9" >
<TargetAddress Value="64" />
<SourceAddress Value="1" />
<FrameType Value="F1" />
<Command Value="NextFrame" />
</HDLC>
11:28:16
<HDLC len="84" >
<FrameType Value="9E" />
<NextFrame Value="630433DCA1D141E9C4BFA7E9CB727328686A66959D69A7ACAE952D96FE46F26CC1A0E39E18280F32E8F4E0A2A01B342A24752CB0BD876CE5585A7602FB07819DF4CEC5C4A50FA6A3A85A91E361298B91F94B79A3895532F63B0EB833175B9D0AD860EAAA8110AD9A3865EACF04AA7F515632AF8B1763F914A4CDB55E" />
</HDLC>
11:28:17
<HDLC len="22" >
<FrameType Value="18" />
<PDU>
<glo_SetResponse Value="3000000269C6F5DA3AD3D885341F531D139DABC45A" />
</PDU>
</HDLC>
11:28:17
<HDLC len="23" >
<FrameType Value="B0" />
<PDU>
<glo_SetRequest Value="300000026B815D8E0AD7643AEFF7CEA4399A4F1023E5" />
</PDU>
</HDLC>
11:28:17
<HDLC len="22" >
<FrameType Value="3A" />
<PDU>
<glo_SetResponse Value="300000026A29E2FEC91FE3BBF1D7E31982008C65B8" />
</PDU>
</HDLC>
Can you send the total trace to me by email? Connect to the meter and try to set write 11 emelements.
You can get my email from here:
https://www.gurux.fi/AboutUs
husainmalkani@…
ok.
ok.
I have mailed the total trace to Email.
