  3. VERDICT: 1.logical_name R- FAILED(No Response)
VERDICT: 1.logical_name R- FAILED(No response)
By viswanath.gowd , 1 November, 2020
Hi Mr. Mike,
During testing of smart meter we are getting below errors:
Client System Title (Tx) = 4354543030303030
Server System Title (Rx) = 56504C3030303031
1. Dedicated Key = DED0D684941FBE416A7A7D6EAF37A940
Log:
13'46.248 READ attribute 1 of instance 0000600102FF of class Data
13'46.273 ENCRYPTION KEY: DED0D684941FBE416A7A7D6EAF37A940, IC: 59E7D3D1,
13'47.230 EXCEPTION (ENoResponse): No response
13'47.240 VERDICT: 1.logical_name R- FAILED(No response)
Tx: 7EA0230002040141FC6969E6E600D0122059E7D3D142E494DB4B5C726E189124C45225AD7E
Rx: 7EA0244100020401FC428AE6E700D482001120000003EA5F85CAB6EB1471BF0B3E14A225967E
2. Dedicated Key = DED0D684941FBE416A7A7D6EAF37A940
Log:
13'48.238 READ attribute 2 of instance 0100000402FF of class Data
13'48.252 ENCRYPTION KEY: DED0D684941FBE416A7A7D6EAF37A940, IC: 59E7D3CF
13'48.409 EXCEPTION (ENoResponse): No response
13'48.423 VERDICT: 2.value R- FAILED(No response)
Tx: 7EA0230002040141F84D2FE6E600D0122059E7D3CE10F5D9B2319E5ABB0C30CF2E4B3A597E
Rx: 7EA0244100020401B8628EE6E700D482001120000003E8F212808278BF6D12E4AFA5455F8F7E
Kindly help us in identifying the issue.
Regards
Viswanath Gowd
5 years 10 months ago
Hi Viswanath Gowd,
Hi Viswanath Gowd,
I believe that reason is that your meter is sending a response when there should be none or then there should be an error. I'm don't know what CTT test this is so I can't tell why the meter shouldn't reply.
You need to check that from the yellow book.
viswanath.gowd
Ok Mr. Mikko. We will explore
Ok Mr. Mikko. We will explore the issue.
Regards
Viswanath Gowd
  • lh
