  2. Communication Profiles
communication profiles
By tagmout , 14 October, 2020
Hi Mikko ,
Can You tell us , the comparison of HDLC and IP profile ?
Thank you in advance .
5 years 8 months ago
IP profile (WRAPPER) is used when communicating over TCP/IP or UDP. There is no checksum, begin or end of the frame. This makes the frame size smaller.
tagmout
5 years 7 months ago
Thank You Mikko for you
Thank You Mikko for you response,
Can You tell us more comparaison between the two communication profiles .
It's not a simple task and it's not possible to do here. They are quite well described in DLMS documentation. You should check them there.
