  3. Invalid Command Exception
By Bhaumik , 24 August, 2020
I am trying to read cumulative energy (1.0.1.6.0.255) from IS15959-2 meter. In that got exception "Invalid command".
Following are the request - response payload to and from meter.
Request : 7ea02c034154af99e6e600c81e3000000023b05779032e47fea0ad388e53488db0122daaf42b52bac250721cb17e
Reponse : 7E A0 23 41 03 74 4C CC E6 E7 00 2E 15 30 00 00 62 3D 91 ED 00 49 01 42 FA 56 FF 9A 55 DC 5F 9C 5B B6 42 9F 7E
Can you please check and provide an update.
5 years 11 months ago
Your meter is returning GloConfirmedServiceError. Because I don't know the authentication and block cipher keys I can't tell the reason why it fails.
We'll add better support for GloConfirmedServiceError so it's decrypted. What programming language you are using?
Bhaumik
I am using c# programming language.
Also, You can use key "0123456798ABCDEF" to verify fail reason.
I also need a server and client system title.
  • FiqJXzPfbTtORWoZ
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
