  3. GXDLMSLimits Object Has No Attribute SetMaxInfoTX (Python)
GXDLMSLimits object has no attribute setMaxInfoTX (Python)
By pylalu , 24 July, 2020
I’m testing my device using Gurux.DLMS.Client.Example.python main.py file executing as follows:
python main.py -h 192.168.0.7 -p 4059 -a Low -P password -c 2 -s 149 -r sn -g 0.0.1.0.0.255:00 -t Verbose
I got the following error:
gurux_dlms version: 1.0.83
gurux_net version: 1.0.17
gurux_serial version: 1.0.14
ClientAddress: 0x2
ServerAddress: 0x95
Standard: Standard.DLMS
TX: 10:39:04 7E A0 08 02 2B 05 93 2C E6 7E
RX: 10:39:04 7E A0 08 05 02 2B 73 05 70 7E
File "main.py", line 87, in main
reader.initializeConnection()
File "/home/laura/Escritorio/Workspace/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 311, in initializeConnection
self.client.parseUAResponse(reply.data)
File "/home/laura/.local/lib/python3.8/site-packages/gurux_dlms/GXDLMSClient.py", line 470, in parseUAResponse
GXDLMS.parseSnrmUaResponse(data, self.settings.limits)
File "/home/laura/.local/lib/python3.8/site-packages/gurux_dlms/GXDLMS.py", line 1986, in parseSnrmUaResponse
limits.setMaxInfoTX(GXDLMSLimits.DEFAULT_MAX_INFO_TX)
AttributeError: 'GXDLMSLimits' object has no attribute 'setMaxInfoTX'
GXDLMSLimit.py file, which contains GXDLMSLimits class definition, doesn’t contain methods that are requested in parseSnrmUaResponse().
Is there any problem with my arguments when client example is executed?
Thanks in advance,
Laura
6 years 3 months ago
Your meter don't return used values. This is fixed to version 1.0.84. Run this:
pip install --upgrade gurux-dlms
