It updates the image to the meter. target is ImageUpdate object. identification is manufacturer specific image name. and data is updated firmware. You can use it to update the image.
i m using the above code but when in ImageUpdate method it goes for "Initiate the Image transfer process" it gives the exception Device reports a hardware fault.
Same file is used in Gurux tool it works fine.
Do i have to update any property of ImageUpdateobject before sending to the ImageUpdate Method
They are using the same library and source code. Check identification and data values?
I believe the reason is in the identification if it fails here. Check that.
foreach (GXDLMSImageActivateInfo it in target.ImageActivateInfo)
if (it.Identification == identification)
bFound = true;
break;
This method is creating problem
Both it.Identification == identification have same value but still it is not entering the loop to get bFound true.
Don't know why both values are showing mismatch instead both are having 9 bytes and same value
Here is an example:
public void ImageUpdate
public void ImageUpdate(GXDLMSImageTransfer target, byte[] identification, byte[] data)
can you explain the info which i have to pass in this method.
What is target and data
GXDLMSImageTransfer
GXDLMSImageTransfer imageTransfer = new GXDLMSImageTransfer();
byte[] ident = ASCIIEncoding.ASCII.GetBytes(tb_identification.Text);
_media.reader.ImageUpdate(imageTransfer, ident, FirmwareBytes);
foreach
bFound = true;
break;
This is fixed. Change this:
to:
if (GXCommon.EqualBytes(it.Identification, identification))
