  3. DLMS Object Serialization
By Bhaumik , 28 January, 2020
I saved COSEM objects using GXDLMSObjectCollection.save.
Now I am getting following XML.
<Objects>
<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.0.255</LN>
<Description>Invalid</Description>
<ApplicationContextName>
<JointIsoCtt>2</JointIsoCtt>
<Country>16</Country>
<CountryName>756</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>8</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
<XDLMSContextInfo>
<DlmsVersionNumber>6</DlmsVersionNumber>
</XDLMSContextInfo>
<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<SecuritySetupReference>0.0.0.0.0.0</SecuritySetupReference>
</GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<DlmsUA>8</DlmsUA>
<XDLMSContextInfo>
</XDLMSContextInfo>
<DlmsUA>8</DlmsUA>
<GXDLMSData>
<LN>0.0.42.0.0.255</LN>
</GXDLMSData>
<GXDLMSClock>
<LN>0.0.1.0.0.255</LN>
</GXDLMSClock>
</Objects>
The problem with this XML is, I am not able to deserialize it.
Can you please suggest any solution so that I can deserialize the XML into GXDLMSObjectCollection?
6 years 6 months ago
You can use the default java serializer to do this. We are using data structure like this because we need to use the same XML format for ANSI C++, Python, Java and C#.
  • Duaneduh
  • ClaytonPap
  • sAYgntkdaTjhgpvfz
  • HenryEneno
  • ScottCab
