  3. Read Data From DLMS_OBJECT_TYPE_DATA
read data from DLMS_OBJECT_TYPE_DATA
By fery_rz , 1 November, 2019
I try to read firmware version from SL7000 meter, using ANSI C. here it's the code:
cosem_init(&data1.base, DLMS_OBJECT_TYPE_DATA, "0.0.142.1.1.255");
ret = com_read(&data1.base, 2);
the response code is "OK".
<Result>
<Data>
<Structure Qty="2" >
<UInt8 Value="4" />
<UInt8 Value="40" />
</Structure>
</Data>
</Result>
then how can I get the value: Uint8 data type "4" and "40"?
what function to get / parse this data? Is there an example?
Thank you,
Best Regard,
Fery
7 years ago
You can access array/structure like this:
dlmsVARIANT* it;
//First value
va_getByIndex(&data1.value.Arr, 0, &it)
ii->bVal
//Second value
va_getByIndex(&data1.value.Arr, 1, &it)
ii->bVal
obj_toString gets content of the object as a string.
fery_rz
7 years ago
Hey Mikko,
Hey Mikko,
thank you for your reply,
and it's work with removing & from the &data1.value.arr
Best Regards,
Fery_rz
fery_rz
7 years ago
Hello Mikko,
Hello Mikko,
can you give example to get data from profile generic?
<Result>
<Data>
<Array Qty="0006" >
<Structure Qty="0004" >
<LongUnsigned Value="0003" />
<OctetString Value="01011F0700FF" />
<Integer Value="00" />
<LongUnsigned Value="0000" />
</Structure>
<OctetString Value="0101330700FF" />
</Structure>
<OctetString Value="0101470700FF" />
</Structure>
<OctetString Value="0101200700FF" />
</Structure>
<OctetString Value="0101340700FF" />
</Structure>
<OctetString Value="0101480700FF" />
</Structure>
</Array>
</Data>
</Result>
for example, I want to get first index of array:
</Structure>
what the function use, to read the "0003", "01011F0700FF", "00", and "0000"?
Best regards,
Fery
7 years ago
Check obj_CaptureObjectsToString. It does exactly this.
obj_toString calls it.
fery_rz
7 years ago
Hello mikko
Hello mikko
unfortunatelly,
I cant find "obj_CaptureObjectsToString" in ANSI C
gxProfileGeneric profile1;
I try to get this, response is OK.
cosem_init(&profile1.base, DLMS_OBJECT_TYPE_PROFILE_GENERIC, "1.1.98.128.4.255");
ret = com_read(&profile1.base, 3);
I check: "profile1.capturedObject.size" = 6, and data Type of the "profile1.capturedObject" is "gxArray"
can we just get the first index of the array, then pass it to "va_getByIndex()"?
then get the value using it->ulVal; for example
if it possible, how to do it?
and also how to get the first index of the array, and what variable Type to store it?
regards,
Fery
7 years ago
obj_CaptureObjectsToString is internal method. obj_toString calls it.
You can also access data like this:
dlmsVARIANT* structure, it;
//First structure
va_getByIndex(&profile1.capturedObject.Arr, 0, &structure);
//First item
va_getByIndex(&structure->.Arr, 0, &it);
//Second item
va_getByIndex(&structure->.Arr, 1, &it);
7 years ago
it->vt tells data type.
fery_rz
7 years ago
I am Sorry Mikko,
I am Sorry Mikko,
but the &profile1.capturedObject is dont have member .Arr, but .data, and the type is void **data. and the captureObject type is gxArray.
and also arr_getByIndex first parameter is variantArray *arr.
or we need to use arr_getByIndex to handle profile1.capturedObjects ?
is there any solution?
Best Regards,
Fery
fery_rz
7 years ago
I've found the obj_CaptureObjectsToString, then I try to implement this
dlmsVARIANT *structure, *it;
arr_getByIndex(&profile1.captureObjects, 0, (void **)&structure);
va_getByIndex(structure->Arr, 0, &it);
but my controller get crash when "va_getByIndex(structure->Arr, 0, &it);" above is added.
just trying to do: printf("%i\r\n", structure->vt);
the result is 1073450804
Fery
7 years ago
Hi Fery,
Hi Fery,
I'm sorry. This was my mistake. Correct example code is:
gxKey* kv;
arr_getByIndex(&profile1.capturedObject, 0, &kv);
gxObject* obj = (gxObject*)kv->key;
Attribute and data index you can get from value.
gxTarget* t = (gxTarget*)kv->value
