  2. How To Set Token Into The Meter (Cannot Set Token Using Action Method)
How to set Token Into the Meter (Cannot Set Token Using Action Method)
By Tauheedul Maruf , 7 March, 2019
I Cannot set Token into the Meter. Can you please suggest how can i Set token into the meter. I can get and set clock information. But while i tried to set Token using TokenGateway class and using Method() from GSDLMSClient it. what should i do can you please suggest? what should be the correct approach?
7 years 4 months ago
I have answerd for your question here:
http://www.gurux.fi/node/13266
  • Kak_nvKr
  • Geraldtup
  • Kak_jhKr
  • qnYAEbyuazdBVm…
  • SkyCrown-AU
