  3. Amount of Meter Supported By Gurux
Amount of meter supported by Gurux
By gcorbaz , 1 March, 2018
Is it possible to manage several tens of thousands of meters on the Gurux Platform ?
Regards, Guy.
8 years 8 months ago
Easily. Don't try to read all the meters at the same time. Make threads that read the meters and
when the meter is read ask next meter to read. In that way, you can manage a number of current readings.
If you try to read all the meters at the same time you need a lot of memory and CPU (you need to create own client for each meter). You can also block your DB if thousands of meters try to update values to the DB at the same time.
leonelc23
8 years 2 months ago
In reply to Amount of meter supported by Gurux by Kurumi
Read a group of meters
Can GuruxDirector "Make threads that read the meters and
when the meter is read ask next meter to read."??
Sorry for my English.
BR, Leo
Current version can't do it. You can make own app using open source version to read your meters.
