  3. Regression On GXDateTime Deviation Field
Regression on GXDateTime deviation field
By Nico , 8 June, 2017
Recently upgrading from Gurux 1.4.5 to 2.1.1, I noticed an issue concerning the setting/getting of the deviation field when creating a GXDateTime object.
This simple unit test below:
@Test
public void testGXDateTime() {
int deviationOne = 60;
GXDateTime dt = new GXDateTime(2017,02,04,12,00,0,0,deviationOne);
int deviationTwo = dt.getDeviation();
assertEquals(deviationOne, deviationTwo);
Gives:
java.lang.AssertionError:
Expected :60
Actual :-60
Could you please confirm that this is an issue?
And would you have any idea on how to fix this ?
nico
9 years 4 months ago
First. Use version 2.1.4. It's the latest.
Standard says that deviation is in minutes of local time to UTC (Page 46 in Blue book). So, if your timezone is 60, deviation is -60. In my mind this is not a good idea and I know that there are lots of meters where deviation = Time Zone. (60=60). But we can't effect to it.
getDeviation returns current time zone to UTC time.
devitation in constructor is actual time zone. There is a historical reason and we can't change this.
I'll have add work list that we'll rename constructor deviation to timeZone.
Nico
In reply to Regression on GXDateTime deviation field by Kurumi
Thanks for your very prompt message.
I am now using version 2.1.4 indeed.
it is true that the name is misleading but your explanation is very clear and helpful - maybe a comment in the source code would prevent confusion ?
Thanks again,
Nico
We have renamed this and added comment also.
Dmitry R.
5 years 1 month ago
Can we be sure enough to consider the deviation the minus-operand to the local time istead of timezone as itself?
Suppose The Blue Book says it ambiguously:
- ... in minutes of local time to UTC (GMT)...
I give it rather plus then minus. Also the diagram in The Blue Book concerning the DST shift handling shows the positive shift at the start of DST (summer) period and the negative one at the end, so don't you think it means that deviation for the +timezones should be positive (i.e. deviation=timezone)?
May be there are any clarifications from the DLMS Association experts, aren't there?
5 years 1 month ago
In reply to Hi, by Dmitry R.
Hi Dmitry,
Hi Dmitry,
Please, create a new topic, if you have a new question. You can get more information from here:
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock#deviation
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
