  3. Cannot Connect To TI Module In HLS(2)
Cannot connect to TI module in HLS(2)
By justthat , 15 April, 2016
Hello everyone,
I just started approaching the world of DLMS/COSEM, in particular the development of a DLMS server. I'm currently using the MSP430 micro from Texas Instruments and both the GuruX Director and java libraries as client.
I have no problems connecting the device using none or low security. Since the Director doesn't have support for High authentication natively (it can be set creating a new manufacturer, but that's not the issue) I started using the client example that comes within the libraries.
I modified the tis.obx to include a new GXAuthentication type named 'High' with Client ID = 48 (0x30H) and set the flag for iec starting protocol to false (since the iec opening is not supported).
With the manufacturer, password and serial port set within the run commands, i got a "Access Error : Device reports a inconsistent Class or object".
I started digging into the function and found out that in the aarq sent to the server there were two elements to pay attention to:
1) the calling-authentication-value (tag AC) with the 16 bytes password set in the run commands
2) the dedicated-key among the user-info field as a randomly generated string.
As far as I understand the CtoS should be set in the calling-authentication-value and since I don't need the APDU encryption I removed the dedicated-key field of the initiate request and set the calling-authentication-value as a fixed 16 bytes randomly generated string just to try.
The device will always reply with "Access Error : Device reports a inconsistent Class or object", still the reply_to_HLS reply has the correct encryption of the CtoS!
So, has anyone succeeded in connecting the TI devices in HLS(2) or am I missing some steps?
Thanks for your help
This is the aarq I send:
60 3e a1 09 06 07 60 85 74 05 08 01 01 8a 02 07 80 8b 07 60 85 74 05 08 02 02 ac 12 80 10 3f 3a 3f 2b 6d 26 2a 6d 5c 3f 32 67 59 27 34 31 be 10 04 0e 01 00 00 00 06 5f 1f 04 00 00 7e 1f ff ff
This is the aare I receive:
61 4a a1 09 06 07 60 85 74 05 08 01 01 a2 03 02 01 0 a3 05 a1 03 02 01 0e 88 02 07 80 89 07 60 85 74 05 08 02 02 aa 12 80 10 54 65 78 61 73 49 6e 73 74 72 75 6d 65 6e 74 73 be 10 04 0e 08 0 06 5f 1f 04 0 0 18 1d 0 64 0 07
This is the action reply_to_HLS call:
c3 01 81 00 0f 00 00 28 00 00 ff 01 01 09 20 02 ac c4 1a 49 2b df e7 bf af 69 f4 53 05 45 2a dc 3a 2c 49 aa 38 5b 0c 67 42 d9 c3 2b 18 12 15 00 00 00 00 00 00 00 00 00 00
This is the reply_to_HLS reply:
c7 01 81 00 01 09 10 a8 e6 14 a7 c6 dd 36 55 2b 6e 1c de 72 be fd 2c
EDIT
I think I got it. In the reply_to_HLS reply I have
c7 01 = Action-Response-Normal
81 = ID & Priority
00 = Action-Result Success
01 = I cannot explain this one (data-access-result)... Since the next bytes are an octect string I was
expecting 0100.
09 10 = octect string of length 16
In fact, if I comment the piece of code that checks for the data-access-result field of the action response, the connection is established.
10 years 7 months ago
Your information is very interesting. We make new version (8.1.0.8) from Gurux.DLMS component.
Can you update to that and let me know is the result same?
Can you send all frames to me using email?
Last frame what you have add here is strange.
justthat
Yes, I tried with that
Yes, I tried with that version as soon as it was released.
Anyway I'll send you an email with all the changes I made in order for the library to connect to the module.
The last frame (I assume you're talking about the reply_to_HLS reply)
is sent by the TI module back to the pc. As far as I know (and using the XMLTranslator tool) it should have been:
c7 01 81 00 01 "00" 09 10 a8 e6 14 a7 c6 dd 36 55 2b 6e 1c de 72 be fd 2c
where
01 = data-access-result is present
00 = (this byte is missing in the TI module reply) data-access-result is of type data
09 = octect string
The same information, about the missing byte that should be there, is posted in the DLMS UA forum here: http://www.dlms.com/faqanswers/forum/index.php?action=view&topicid=319
I already submitted a ticket to TI to check if it's a bug or something else.
Yes, I was talking from last frame and you found answer for my question.
I was thinking is that byte 0x00 really missing or is that copy/paste issue.
We will audit messages and send a report to TI if that byte is really missing and messages are correct.
iMeter
10 years 5 months ago
HLS possible error
src GXDLMSClient.cs
ParseApplicationAssociationResponse
//Skip item count
++index;
//Skip item status
++index;
structure can be
invoke ID and priority, success. 0x81,0x00
0x01 // Get-Data-Result present
0x00 // Data CHOICE
Tag Octet String(byte)
Length(byte)
  • Victorian | WA 083148835648
