  3. Incorrect Timezone Offset Calculation
Incorrect timezone offset calculation
By eriktrif , 17 July, 2026
Project
Gurux.DLMS.Python
Status
Closed (fixed)
Incorrect timezone offset calculation in setDateTime() in _GXCommon.py
Current code:
d = int(dt.value.utcoffset().seconds / 60)
Should be:
d = int(dt.value.utcoffset().total_seconds() / 60)
Reason:
timedelta.seconds does not preserve the sign of the timedelta. It returns only the seconds component in the range 0...86399.
For example, for UTC-3 offset:
timedelta(seconds=-10800).seconds
returns 75600 instead of -10800.
As a result, negative UTC offsets are encoded incorrectly.
total_seconds() correctly preserves the sign of the offset.
Priority
Normal
Category
Bug report
2 months 2 weeks ago
Hi, Thank you for pointing…
Thank you for pointing this out. It was easy to verify with the current time and a negative time zone.
dt = datetime(2026, 8, 17, 12, 0, 0,tzinfo=timezone(timedelta(hours=-3)))
This is fixed in version 1.0.202, and your name is added to the credits.
