  2. Profile Generic Read By Range Returned An Error Despite Data Exist On Itron SL7000
Profile Generic Read by Range returned an error despite data exist on Itron SL7000
Profile picture for user jack 001
By jack 001 , 21 October, 2025
Gurux DLMS for ANSI C
Hi Mikko, good day.
I have with me an Itron SL7000 meter. Using correct parameters I can connect to it and read some data using Gurux DLMS Director. I managed to read the daily load profile by range. Then i try to read using ESP32. I can connect to it using ESP32, but when i try to read load profile by range, the code throws some errors. Here's the code that i use:
gxProfileGeneric pgLoadProfile;
  cosem_init(BASE(pgLoadProfile), DLMS_OBJECT_TYPE_PROFILE_GENERIC, "0.0.99.1.0.255");
  com_read(BASE(pgLoadProfile), 3);
  // com_readProfileGenericColumns();
  gxtime start1, end1;
  time_init(&start1  ,2024,6,6,00,00,00,0000,0x8000);
  time_init(&end1  ,2024,6,7,0,15,00,0000,0x8000);
  int retPg;
  if ((retPg = com_readRowsByRange(&pgLoadProfile, &start1, &end1)) != DLMS_ERROR_CODE_OK)
    GXTRACE_INT(GET_STR_FROM_EEPROM("com_readRowsByRange failed."), retPg);
  obj_toString(BASE(pgLoadProfile), &data);
  GXTRACE(GET_STR_FROM_EEPROM("\nprofileGeneric >> "), data);
  free(data);
  obj_clear(BASE(pgLoadProfile));
With that code, i get error 13 which is DLMS_ERROR_CODE_ACCESS_VIOLATED. Here's the trace :
:com_initializeConnection SUCCEEDED 0   :
 0      :
TX: 7E A0 1C 00 02 00 23 03 32 1C 38 E6 E6 00 C0 01 C1 00 07 00 00 63 01 00 FF 03 00 33 11 7E   :
RX: 7E A8 8C 03 00 02 00 23 52 9D A9 E6 E7 00 C4 01 C1 00 01 0C 02 04 12 00 01 09 06 00 00 60 37 01 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 37 02 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 37 03 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 37 04 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 03 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 20 1B 6C 5C 7E   :
TX: 7E A0 0A 00 02 00 23 03 51 85 84 7E :
RX: 7E A0 6D 03 00 02 00 23 54 5A 5C 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 34 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 48 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 1F 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 33 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 47 1B 00 FF 0F 02 12 00 00 4A 49 7E        :
TX: 7E A0 3D 00 02 00 23 03 74 78 E3 E6 E6 00 C0 01 C1 00 07 00 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 01 09 06 00 00 60 37 01 FF 0F 02 12 00 00 06 66 60 FC 00 06 66 62 51 04 01 00 38 27 7E        :
RX: 7E A0 14 03 00 02 00 23 76 3F 0E E6 E7 00 C4 01 C1 01 0D 0D 6B 7E   :com_readRowsByRange failed. 13 :com_readRowsByRange failed. 13 :
profileGeneric >> Index: 2 Value: [
Index: 3 Value: [Data 0.0.96.55.1.255, Data 0.0.96.55.2.255, Data 0.0.96.55.3.255, Data 0.0.96.55.4.255, Register 1.1.1.29.0.255, Register 1.1.3.29.0.255, Register 1.1.32.27.0.255, Register 1.1.52.27.0.255, Register 1.1.72.27.0.255, Register 1.1.31.27.0.255, Register 1.1.51.27.0.255, Register 1.1.71.27.0.255]
Index: 4 Value: 0
Index: 5 Value: 0
Index: 6 Value:
Index: 7 Value: 0
Then i tried to directly read the buffer by commenting out the
Now the read process took roughly the same amount of time compared to Gurux DLMS Director, so i checked the trace and indeed, there are some data. The error is still present but different, now it's error 258 (DLMS_ERROR_CODE_INVALID_PARAMETER). Here's the trace:
TX: 7E A0 4F 00 02 00 23 03 32 BD E2 E6 E6 00 C0 01 C1 00 07 00 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 06 06 04 00 00 00 00 80 00 00 09 0C 07 E8 06 07 05 00 0F 00 00 80 00 00 01 00 78 DF 7E  :
RX: 7E A8 8C 03 00 02 00 23 52 9D A9 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 06 4A 01 60 02 0C 02 02 09 0C 07 E8 06 06 FF FF FF FF FF 80 00 FF 04 06 00 00 00 00 10 00 F1 10 00 24 10 08 BE 10 08 B2 10 08 AF 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F0 10 00 24 10 08 BD 10 08 B1 10 08 AE 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F0 10 00 24 10 08 BC 10 08 B0 10 08 AD 10 00 04 10 00 41 10 01 AE 02 0C 00 16 75 7E   :
RX: 7E A8 8C 03 00 02 00 23 54 AB CC 00 00 00 10 00 F1 10 00 23 10 08 BC 10 08 B1 10 08 AE 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F1 10 00 24 10 08 BD 10 08 B2 10 08 AF 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F0 10 00 24 10 08 BD 10 08 B2 10 08 AF 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F2 10 00 24 10 08 BE 10 08 B2 10 08 AF 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F0 10 00 18 1E 7E   :
TX: 7E A0 0A 00 02 00 23 03 71 87 A5 7E :
RX: 7E A8 8C 03 00 02 00 23 56 B9 EF 24 10 08 BF 10 08 B3 10 08 B0 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F2 10 00 23 10 08 C2 10 08 B5 10 08 B2 10 00 04 10 00 41 10 01 AD 02 0C 00 00 00 00 10 00 F1 10 00 24 10 08 C3 10 08 B7 10 08 B4 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F2 10 00 23 10 08 C5 10 08 B9 10 08 B6 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F2 10 00 23 10 08 C5 10 08 B9 10 35 D7 7E   :
TX: 7E A0 0A 00 02 00 23 03 91 89 42 7E :
RX: 7E A8 8C 03 00 02 00 23 58 C7 06 08 B7 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F2 10 00 23 10 08 C6 10 08 BA 10 08 B7 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F2 10 00 23 10 08 C7 10 08 BB 10 08 B8 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F2 10 00 24 10 08 C9 10 08 BD 10 08 BA 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F2 10 00 23 10 08 CA 10 08 BE 10 08 BB 10 00 04 10 00 41 D5 BC 7E   :
TX: 7E A0 0A 00 02 00 23 03 B1 8B 63 7E :
RX: 7E A8 8C 03 00 02 00 23 5A D5 25 10 01 B0 02 0C 00 00 00 00 10 00 F3 10 00 23 10 08 CB 10 08 BE 10 08 BB 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F2 10 00 24 10 08 CB 10 08 BE 10 08 BB 10 00 05 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F2 10 00 24 10 08 CA 10 08 BE 10 08 BA 10 00 04 10 00 41 10 01 AF 02 0C 00 00 00 00 10 00 F3 10 00 23 10 08 CA 10 08 BD 10 08 B9 10 00 05 10 00 41 10 01 AF 02 0C 00 00 00 73 2B 7E   :
TX: 7E A0 0A 00 02 00 23 03 D1 8D 00 7E :
RX: 7E A8 8C 03 00 02 00 23 5C E3 40 00 10 00 F1 10 00 23 10 08 C4 10 08 B7 10 08 B5 10 00 04 10 00 41 10 01 AE 02 0C 00 00 00 00 10 00 F1 10 00 24 10 08 C0 10 08 B3 10 08 B0 10 00 04 10 00 41 10 01 AD 02 0C 00 00 00 00 10 01 0D 10 00 25 10 08 B9 10 08 AD 10 08 A9 10 00 04 10 00 41 10 01 DB 02 0C 00 00 00 00 10 00 F5 10 00 25 10 08 B6 10 08 AA 10 08 A7 10 00 04 10 00 41 10 01 B4 02 0C 00 00 00 00 10 00 F9 10 00 24 10 A1 68 7E   :
TX: 7E A0 0A 00 02 00 23 03 F1 8F 21 7E :
RX: 7E A8 8C 03 00 02 00 23 5E F1 63 08 B4 10 08 A8 10 08 A5 10 00 04 10 00 41 10 01 BA 02 0C 00 00 00 00 10 00 EF 10 00 25 10 08 B2 10 08 A6 10 08 A4 10 00 04 10 00 41 10 01 A9 02 0C 00 00 00 00 10 00 F3 10 00 25 10 08 B0 10 08 A5 10 08 A2 10 00 04 10 00 41 10 01 B0 02 0C 00 00 00 00 10 00 F4 10 00 25 10 08 B0 10 08 A5 10 08 A3 10 00 04 10 00 41 10 01 B0 02 0C 00 00 00 00 10 00 EE 10 00 24 10 08 AC 10 08 A1 10 08 9F D6 C6 7E   :
TX: 7E A0 0A 00 02 00 23 03 11 81 C6 7E :
RX: 7E A8 8C 03 00 02 00 23 50 8F 8A 10 00 04 10 00 41 10 01 A6 02 0C 00 00 00 00 10 00 E8 10 00 23 10 08 A7 10 08 9D 10 08 9A 10 00 04 10 00 41 10 01 98 02 0C 00 00 00 00 10 00 8C 10 00 10 10 08 A7 10 08 A0 10 08 9D 10 00 04 10 00 41 10 00 D3 02 0C 00 00 00 00 10 00 83 10 00 11 10 08 B9 10 08 B2 10 08 B0 10 00 04 10 00 40 10 00 C2 02 0C 00 00 00 00 10 00 83 10 00 11 10 08 A2 10 08 9C 10 08 9A 10 00 05 10 00 41 10 00 74 AE 7E   :
TX: 7E A0 0A 00 02 00 23 03 31 83 E7 7E :
RX: 7E A8 8C 03 00 02 00 23 52 9D A9 C2 02 0C 00 00 00 00 10 00 83 10 00 11 10 08 AC 10 08 A5 10 08 A4 10 00 05 10 00 41 10 00 C2 02 0C 00 00 00 00 10 00 7F 10 00 12 10 08 AE 10 08 A9 10 08 A7 10 00 05 10 00 41 10 00 BA 02 0C 00 00 00 00 10 00 83 10 00 12 10 08 AA 10 08 A5 10 08 A4 10 00 05 10 00 41 10 00 C2 02 0C 00 00 00 00 10 00 84 10 00 11 10 08 A5 10 08 A1 10 08 A0 10 00 05 10 00 41 10 00 C2 02 0C 00 00 00 00 10 95 52 7E   :
RX: 7E A8 8C 03 00 02 00 23 54 AB CC 00 7E 10 00 11 10 08 A1 10 08 9D 10 08 9C 10 00 05 10 00 41 10 00 B9 02 0C 00 00 00 00 10 00 83 10 00 11 10 08 A0 10 08 9B 10 08 9A 10 00 04 10 00 41 10 00 C2 02 0C 00 00 00 00 10 00 84 10 00 11 10 08 9C 10 08 98 10 08 96 10 00 04 10 00 40 10 00 C3 02 0C 00 00 00 00 10 01 0E 10 00 33 10 08 9D 10 08 95 10 08 91 10 00 04 10 00 41 10 01 ED 02 0C 00 00 00 00 10 01 0F 10 00 33 10 08 9C 3B 86 7E   :
RX: 7E A8 8C 03 00 02 00 23 56 B9 EF 10 08 93 10 08 8F 10 00 04 10 00 41 10 01 F4 02 0C 00 00 00 00 10 00 EB 10 00 2A 10 08 9A 10 08 92 10 08 8E 10 00 04 10 00 41 10 01 A4 02 0C 00 00 00 00 10 00 85 10 00 10 10 08 96 10 08 91 10 08 8F 10 00 05 10 00 41 10 00 C6 02 0C 00 00 00 00 10 01 0D 10 00 34 10 08 98 10 08 8F 10 08 8B 10 00 04 10 00 41 10 01 EF 02 0C 00 00 00 00 10 00 84 10 00 10 10 08 96 10 08 92 10 08 8F 10 00 25 60 7E   :
RX: 7E A8 8C 03 00 02 00 23 58 C7 06 05 10 00 3F 10 00 C5 02 0C 00 00 00 00 10 00 80 10 00 10 10 08 98 10 08 93 10 08 90 10 00 04 10 00 3E 10 00 C1 02 0C 00 00 00 00 10 00 7C 10 00 11 10 08 9E 10 08 99 10 08 96 10 00 04 10 00 3E 10 00 B9 02 0C 00 00 00 00 10 00 80 10 00 11 10 08 A2 10 08 9C 10 08 99 10 00 05 10 00 3E 10 00 C1 02 0C 00 00 00 00 10 00 7A 10 00 12 10 08 A4 10 08 9E 10 08 9B 10 00 04 10 00 3E 10 00 B1 02 ED 27 7E   :
RX: 7E A0 65 03 00 02 00 23 5A C8 6B 0C 00 00 00 00 10 00 72 10 00 12 10 08 A6 10 08 A1 10 08 9E 10 00 05 10 00 3E 10 00 A5 02 0C 00 00 00 00 10 00 78 10 00 13 10 08 A8 10 08 A3 10 08 A0 10 00 05 10 00 3E 10 00 AE 02 0C 00 00 00 00 10 00 7A 10 00 12 10 08 A5 10 08 A1 10 08 9F 10 00 05 10 00 3E 10 00 B3 79 BF 7E        :
TX: 7E A0 16 00 02 00 23 03 D4 73 53 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E     :
RX: 7E A8 8C 03 00 02 00 23 7C E1 61 E6 E7 00 C4 02 C1 01 00 00 00 02 00 82 05 0A 02 0C 00 00 00 00 10 00 78 10 00 14 10 08 B7 10 08 B3 10 08 B1 10 00 05 10 00 3E 10 00 AF 02 0C 00 00 00 00 10 00 92 10 00 10 10 08 B6 10 08 B2 10 08 B0 10 00 05 10 00 3E 10 00 E2 02 0C 00 00 00 00 10 00 E9 10 00 08 10 08 B6 10 08 AF 10 08 AB 10 00 05 10 00 3E 10 01 92 02 0C 00 00 00 00 10 00 EA 10 00 09 10 08 B5 10 08 AF 10 08 AB 10 00 B1 5E 7E   :
RX: 7E A8 8C 03 00 02 00 23 7E F3 42 05 10 00 3E 10 01 95 02 0C 00 00 00 00 10 00 EB 10 00 09 10 08 B5 10 08 B0 10 08 AB 10 00 04 10 00 3E 10 01 96 02 0C 00 00 00 00 10 00 E6 10 00 09 10 08 B6 10 08 B1 10 08 AC 10 00 04 10 00 3E 10 01 8E 02 0C 00 00 00 00 10 00 EA 10 00 0A 10 08 B7 10 08 B2 10 08 AD 10 00 04 10 00 3E 10 01 94 02 0C 00 00 00 00 10 00 83 10 00 13 10 08 B7 10 08 B5 10 08 B2 10 00 05 10 00 3E 10 00 C2 02 79 D7 7E   :
RX: 7E A8 8C 03 00 02 00 23 70 8D AB 0C 00 00 00 00 10 00 79 10 00 14 10 08 B9 10 08 B6 10 08 B4 10 00 04 10 00 3D 10 00 AF 02 0C 00 00 00 00 10 00 75 10 00 14 10 08 BC 10 08 B9 10 08 B7 10 00 05 10 00 3D 10 00 A8 02 0C 00 00 00 00 10 00 78 10 00 14 10 08 BF 10 08 BB 10 08 BA 10 00 04 10 00 3E 10 00 AD 02 0C 00 00 00 00 10 00 75 10 00 14 10 08 C2 10 08 BE 10 08 BD 10 00 04 10 00 3D 10 00 A7 02 0C 00 00 00 00 10 00 75 66 BD 7E   :
RX: 7E A8 8C 03 00 02 00 23 72 9F 88 10 00 15 10 08 C1 10 08 BD 10 08 BC 10 00 05 10 00 3D 10 00 A7 02 0C 00 00 00 00 10 00 74 10 00 14 10 08 B9 10 08 B5 10 08 B4 10 00 04 10 00 3E 10 00 A7 02 0C 00 00 00 00 10 00 73 10 00 13 10 08 AD 10 08 A9 10 08 A8 10 00 04 10 00 3E 10 00 A5 02 0C 00 00 00 00 10 00 73 10 00 13 10 08 B3 10 08 AF 10 08 AE 10 00 05 10 00 3E 10 00 A6 02 0C 00 00 00 00 10 00 74 10 00 14 10 08 B7 10 08 ED 05 7E   :
RX: 7E A8 8C 03 00 02 00 23 74 A9 ED B2 10 08 B2 10 00 05 10 00 3E 10 00 A8 02 0C 00 00 00 00 10 00 74 10 00 13 10 08 B9 10 08 B3 10 08 B3 10 00 05 10 00 3E 10 00 A7 02 0C 00 00 00 00 10 00 75 10 00 14 10 08 BB 10 08 B6 10 08 B5 10 00 04 10 00 3E 10 00 A7 02 0C 00 00 00 00 10 00 74 10 00 14 10 08 C0 10 08 BA 10 08 B8 10 00 05 10 00 3E 10 00 A8 02 0C 00 00 00 00 10 00 BB 10 00 1C 10 08 C4 10 08 BC 10 08 B9 10 00 05 10 6D F5 7E   :
RX: 7E A8 8C 03 00 02 00 23 76 BB CE 00 3E 10 01 3B 02 0C 00 00 00 00 10 00 E1 10 00 1F 10 08 C7 10 08 BE 10 08 BA 10 00 05 10 00 3E 10 01 8B 02 0C 00 00 00 00 10 00 E2 10 00 20 10 08 C9 10 08 BF 10 08 BC 10 00 04 10 00 3E 10 01 8C 02 0C 00 00 00 00 10 00 E3 10 00 20 10 08 C8 10 08 BE 10 08 BB 10 00 04 10 00 3E 10 01 8C 02 0C 00 00 00 00 10 00 E3 10 00 1F 10 08 C6 10 08 BD 10 08 BA 10 00 04 10 00 3E 10 01 8E 02 0C 00 08 26 7E   :
RX: 7E A8 8C 03 00 02 00 23 78 C5 27 00 00 00 10 00 E2 10 00 20 10 08 C7 10 08 BE 10 08 BB 10 00 04 10 00 3E 10 01 8F 02 0C 00 00 00 00 10 00 D4 10 00 1E 10 08 C8 10 08 BF 10 08 BC 10 00 04 10 00 3E 10 01 70 02 0C 00 00 00 00 10 00 76 10 00 14 10 08 C6 10 08 C0 10 08 BE 10 00 05 10 00 3E 10 00 AA 02 0C 00 00 00 00 10 00 75 10 00 14 10 08 C6 10 08 C0 10 08 BE 10 00 05 10 00 3E 10 00 AA 02 0C 00 00 00 00 10 00 75 10 00 CB D6 7E   :
RX: 7E A8 8C 03 00 02 00 23 7A D7 04 14 10 08 C6 10 08 C0 10 08 BD 10 00 05 10 00 3E 10 00 A9 02 0C 00 00 00 00 10 00 76 10 00 14 10 08 C8 10 08 C1 10 08 BF 10 00 04 10 00 3E 10 00 A9 02 0C 00 00 00 00 10 00 75 10 00 15 10 08 C9 10 08 C1 10 08 C0 10 00 05 10 00 3E 10 00 AA 02 0C 00 00 00 00 10 00 76 10 00 14 10 08 C9 10 08 C2 10 08 C0 10 00 05 10 00 3E 10 00 A9 02 0C 00 00 00 00 10 00 75 10 00 14 10 08 C7 10 08 C0 10 32 8D 7E   :
RX: 7E A8 8C 03 00 02 00 23 7C E1 61 08 BE 10 00 05 10 00 3E 10 00 A9 02 0C 00 00 00 00 10 00 75 10 00 13 10 08 C2 10 08 BC 10 08 B9 10 00 05 10 00 3E 10 00 A9 02 0C 00 00 00 00 10 00 74 10 00 13 10 08 B2 10 08 AB 10 08 A8 10 00 05 10 00 3F 10 00 A8 02 0C 00 00 00 00 10 00 73 10 00 12 10 08 B1 10 08 AA 10 08 A8 10 00 05 10 00 3F 10 00 A8 02 0C 00 00 00 00 10 00 74 10 00 12 10 08 B3 10 08 AB 10 08 A9 10 00 05 10 00 3F F5 7C 7E   :
RX: 7E A8 8C 03 00 02 00 23 7E F3 42 10 00 A8 02 0C 00 00 00 00 10 00 74 10 00 13 10 08 B7 10 08 AF 10 08 AD 10 00 05 10 00 3F 10 00 A8 02 0C 00 00 00 00 10 00 74 10 00 13 10 08 B8 10 08 B0 10 08 AF 10 00 05 10 00 3F 10 00 A8 02 0C 00 00 00 00 10 00 74 10 00 12 10 08 B7 10 08 AF 10 08 AE 10 00 05 10 00 3F 10 00 A8 02 0C 00 00 00 00 10 00 74 10 00 14 10 08 B9 10 08 B2 10 08 B0 10 00 05 10 00 3F 10 00 A8 02 0C 00 00 00 BC 86 7E   :
RX: 7E A0 25 03 00 02 00 23 70 96 22 00 10 00 75 10 00 12 10 08 BC 10 08 B5 10 08 B3 10 00 04 10 00 3F 10 00 AA D5 D6 7E        :com_readRowsByRange failed. 258        :com_readRowsByRange failed. 258        :
Index: 3 Value: []
Index: 4 Value: 0
Index: 5 Value: 0
Index: 6 Value:
Index: 7 Value: 0
Index: 8 Value: 0
Using the Gurux Data to XML, i grab the block and put it in there, and i got :
Data:
0160020C0202090C07E80606FFFFFFFFFF8000FF0406000000001000F11000241008BE1008B21008AF1000041000411001AF020C000000001000F01000241008BD1008B11008AE1000041000411001AE020C000000001000F01000241008BC1008B01008AD1000041000411001AE020C000000001000F11000231008BC1008B11008AE1000041000411001AE020C000000001000F11000241008BD1008B21008AF1000041000411001AE020C000000001000F01000241008BD1008B21008AF1000041000411001AE020C000000001000F21000241008BE1008B21008AF1000041000411001AE020C000000001000F01000241008BF1008B31008B01000041000411001AE020C000000001000F21000231008C21008B51008B21000041000411001AD020C000000001000F11000241008C31008B71008B41000041000411001AE020C000000001000F21000231008C51008B91008B61000041000411001AE020C000000001000F21000231008C51008B91008B71000041000411001AF020C000000001000F21000231008C61008BA1008B71000041000411001AF020C000000001000F21000231008C71008BB1008B81000041000411001AF020C000000001000F21000241008C91008BD1008BA1000041000411001AF020C000000001000F21000231008CA1008BE1008BB1000041000411001B0020C000000001000F31000231008CB1008BE1008BB1000041000411001AF020C000000001000F21000241008CB1008BE1008BB1000051000411001AE020C000000001000F21000241008CA1008BE1008BA1000041000411001AF020C000000001000F31000231008CA1008BD1008B91000051000411001AF020C000000001000F11000231008C41008B71008B51000041000411001AE020C000000001000F11000241008C01008B31008B01000041000411001AD020C0000000010010D1000251008B91008AD1008A91000041000411001DB020C000000001000F51000251008B61008AA1008A71000041000411001B4020C000000001000F91000241008B41008A81008A51000041000411001BA020C000000001000EF1000251008B21008A61008A41000041000411001A9020C000000001000F31000251008B01008A51008A21000041000411001B0020C000000001000F41000251008B01008A51008A31000041000411001B0020C000000001000EE1000241008AC1008A110089F1000041000411001A6020C000000001000E81000231008A710089D10089A100004100041100198020C0000000010008C1000101008A71008A010089D1000041000411000D3020C000000001000831000111008B91008B21008B01000041000401000C2020C000000001000831000111008A210089C10089A1000051000411000C2020C000000001000831000111008AC1008A51008A41000051000411000C2020C0000000010007F1000121008AE1008A91008A71000051000411000BA020C000000001000831000121008AA1008A51008A41000051000411000C2020C000000001000841000111008A51008A11008A01000051000411000C2020C0000000010007E1000111008A110089D10089C1000051000411000B9020C000000001000831000111008A010089B10089A1000041000411000C2020C0000000010008410001110089C1008981008961000041000401000C3020C0000000010010E10003310089D1008951008911000041000411001ED020C0000000010010F10003310089C10089310088F1000041000411001F4020C000000001000EB10002A10089A10089210088E1000041000411001A4020C0000000010008510001010089610089110088F1000051000411000C6020C0000000010010D10003410089810088F10088B1000041000411001EF020C0000000010008410001010089610089210088F10000510003F1000C5020C0000000010008010001010089810089310089010000410003E1000C1020C0000000010007C10001110089E10089910089610000410003E1000B9020C000000001000801000111008A210089C10089910000510003E1000C1020C0000000010007A1000121008A410089E10089B10000410003E1000B1020C000000001000721000121008A61008A110089E10000510003E1000A5020C000000001000781000131008A81008A31008A010000510003E1000AE020C0000000010007A1000121008A51008A110089F10000510003E1000B3
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
Data to XML:
<Array Qty="60" >
  <Structure Qty="0C" >
    <Structure Qty="02" >
      <!-- 06/06/2024 *:*:* -->
      <OctetString Value="07E80606FFFFFFFFFF8000FF" />
      <BitString Value="000000" />
    </Structure>
    <None />
    <None />
    <None />
    <Int16 Value="00F1" />
    <Int16 Value="0024" />
    <Int16 Value="08BE" />
    <Int16 Value="08B2" />
    <Int16 Value="08AF" />
    <Int16 Value="0004" />
    <Int16 Value="0041" />
    <Int16 Value="01AF" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00F0" />
    <Int16 Value="08BD" />
    <Int16 Value="08B1" />
    <Int16 Value="08AE" />
    <Int16 Value="01AE" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08BC" />
    <Int16 Value="08B0" />
    <Int16 Value="08AD" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0023" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00F2" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08BF" />
    <Int16 Value="08B3" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C2" />
    <Int16 Value="08B5" />
    <Int16 Value="01AD" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C3" />
    <Int16 Value="08B7" />
    <Int16 Value="08B4" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C5" />
    <Int16 Value="08B9" />
    <Int16 Value="08B6" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C6" />
    <Int16 Value="08BA" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C7" />
    <Int16 Value="08BB" />
    <Int16 Value="08B8" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C9" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08CA" />
    <Int16 Value="01B0" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00F3" />
    <Int16 Value="08CB" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0005" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C4" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08C0" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="010D" />
    <Int16 Value="0025" />
    <Int16 Value="08A9" />
    <Int16 Value="01DB" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00F5" />
    <Int16 Value="08AA" />
    <Int16 Value="08A7" />
    <Int16 Value="01B4" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00F9" />
    <Int16 Value="08A8" />
    <Int16 Value="08A5" />
    <Int16 Value="01BA" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00EF" />
    <Int16 Value="08A6" />
    <Int16 Value="08A4" />
    <Int16 Value="01A9" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="08A2" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00F4" />
    <Int16 Value="08A3" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00EE" />
    <Int16 Value="08AC" />
    <Int16 Value="08A1" />
    <Int16 Value="089F" />
    <Int16 Value="01A6" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00E8" />
    <Int16 Value="089D" />
    <Int16 Value="089A" />
    <Int16 Value="0198" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="008C" />
    <Int16 Value="0010" />
    <Int16 Value="08A0" />
    <Int16 Value="00D3" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0083" />
    <Int16 Value="0011" />
    <Int16 Value="0040" />
    <Int16 Value="00C2" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="089C" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="007F" />
    <Int16 Value="0012" />
    <Int16 Value="00BA" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0084" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="007E" />
    <Int16 Value="00B9" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="089B" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0898" />
    <Int16 Value="0896" />
    <Int16 Value="00C3" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="010E" />
    <Int16 Value="0033" />
    <Int16 Value="0895" />
    <Int16 Value="0891" />
    <Int16 Value="01ED" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="010F" />
    <Int16 Value="0893" />
    <Int16 Value="088F" />
    <Int16 Value="01F4" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00EB" />
    <Int16 Value="002A" />
    <Int16 Value="0892" />
    <Int16 Value="088E" />
    <Int16 Value="01A4" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0085" />
    <Int16 Value="00C6" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0034" />
    <Int16 Value="088B" />
    <Int16 Value="01EF" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="003F" />
    <Int16 Value="00C5" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0080" />
    <Int16 Value="0890" />
    <Int16 Value="003E" />
    <Int16 Value="00C1" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="007C" />
    <Int16 Value="089E" />
    <Int16 Value="0899" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="007A" />
    <Int16 Value="00B1" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0072" />
    <Int16 Value="00A5" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0078" />
    <Int16 Value="0013" />
    <Int16 Value="00AE" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00B3" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0014" />
    <Int16 Value="00AF" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0092" />
    <Int16 Value="00E2" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00E9" />
    <Int16 Value="0008" />
    <Int16 Value="08AB" />
    <Int16 Value="0192" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00EA" />
    <Int16 Value="0009" />
    <Int16 Value="0195" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0196" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00E6" />
    <Int16 Value="018E" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="000A" />
    <Int16 Value="0194" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0079" />
    <Int16 Value="003D" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0075" />
    <Int16 Value="00A8" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00AD" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00A7" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0015" />
    <Int16 Value="08C1" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0074" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0073" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00A6" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00BB" />
    <Int16 Value="001C" />
    <Int16 Value="013B" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00E1" />
    <Int16 Value="001F" />
    <Int16 Value="018B" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0020" />
    <Int16 Value="018C" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00E3" />
    <Int16 Value="08C8" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="018F" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00D4" />
    <Int16 Value="001E" />
    <Int16 Value="0170" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="0076" />
    <Int16 Value="00AA" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
    <Int16 Value="00A9" />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
    <None />
    <None />
    <None />
    <None />
  </Structure>
</Array>
Assuming the data read using esp32 succeeded, i expect some column to show null/nothing if there is no value, and show something if there is value, just like normal read when reading another meter. how can i get the profile generic data using ESP32 when i read by range?
Thank you
jack
9 months 2 weeks ago
Hi, Have you added the…
Have you added the capture objects manually or read them from the meter? Now the first object is the data object with OBIS code 0.0.96.55.1.255.
With our customers' meters, that is a clock object with OBIS code 0.0.1.0.0.255.
The read fails because the client now sends the EPOCH time, not the octet string, as the meter expects.
You need to check that.
jack 001
9 months 1 week ago
Hi Mikko, thanks for the…
Hi Mikko, thanks for the answer. You're right, that is the first column in the profile. But i can get the data using Gurux Director. Regarding the capture objects, i first read them from the meter, consider this code:
cosem_init(BASE(pgLoadProfile), DLMS_OBJECT_TYPE_PROFILE_GENERIC, "0.0.99.1.0.255"); com_read(BASE(pgLoadProfile), 3); // capture objects read
com_read(BASE(pgLoadProfile), 2);
Since it didnt return the data, i tried commenting it out and from the trace, i get the data but the data is not printed out. Instead, it throws error code 13
After i checked i noticed that the request frame that get send using the C code is different, with the Gurux showing proper request using date and range. Here's the trace when i use Gurux Director vs the code:
// using gurux director
13:34:56 Reading profile generic data
TX:	 7E A0 4F 00 02 00 23 03 32 BD E2 E6 E6 00 C0 01 C1 00 07 00 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E9 0A 14 FF 00 00 00 FF 80 00 00 09 0C 07 E9 0A 15 FF 00 00 00 FF 80 00 00 01 00 A6 7D 7E
// using the code
The Gurux Director app uses the 0.0.1.0.0.255 clock object, how can i replicate this?
Here's my current attempt at doing that:
  gxClock k;
  cosem_init(BASE(k), DLMS_OBJECT_TYPE_CLOCK, "0.0.1.0.0.255");
  // com_read(BASE(pgLoadProfile), 2);
  time_init(&start1  ,2024,5,3,00,00,00,0000,0x8000);
  time_init(&end1  ,2024,5,4,00,00,00,0000,0x8000);
  int ret_pg = com_readRowsByRange(&pgLoadProfile, &start1, &end1);
  free(data);
But it still give same error code : access violated
9 months 1 week ago
Hi, What is the sort object…
What is the sort object value in GXDLMSDirector?
jack 001
9 months 1 week ago
Unfortunately i don't know,…
Unfortunately i don't know, because my current association has "NoAccess" listed in the Access column, and that's the only association i have
The only access i have is "Read" on attribute 1,2,3
jack 001
9 months 1 week ago
Hi Mikko, it's been quite a…
Hi Mikko, it's been quite a while, i need your assistance regarding this.
I think one solution would be to set the sort object to Clock object, that way it can operate just like the Gurux Director app. Can i set the sort object to Clock object (OBIS LN 0.0.1.0.0.255) ?
The other solution that i can think of is converting that generated epoch time to octetstring, is it possible?
Thank you
jack
9 months ago
Hi, Get the latest version…
Get the latest version. The sort object support has been improved to ANSI C.
