  3. Testing Periodic Push From Meter To Client Using Gurux DLMS C Server Example
Testing Periodic Push from Meter to Client using Gurux DLMS C Server Example
By Harshi_554 , 23 July, 2025
Gurux DLMS for ANSI C
I am using GuruxDLMSServerExample as a example for meter. I want to test push object sending from meter to client periodically. How do I test it? Which C function is used for the creation of push object list and sending the push object? Is this push operation is supported in DLMS C library?
1 year 3 months ago
Hi, 1. add push setup object…
1. add push setup object and set the wanted objects. Then set the destination IP address e.g. 192.168.68.50:4059. When you press the Push button the push message is sent to the given IP address.
2. Add a Script table object that invokes the push setup.
3. Add an Action Schedule object that calls the script table and sets the wanted times. E.g., *.*.00 will invoke the schedule once per minute.
Harshi_554
1 year 3 months ago
Can you share the necessary…
Can you share the necessary changes to be done in source code?
1 year 3 months ago
Hi, Check addPushSetup,…
Check addPushSetup, addscriptTablePush, and addActionSchedulePush.
https://github.com/Gurux/GuruxDLMS.c/blob/master/GuruxDLMSServerExample…
Harshi_554
1 year 3 months ago
Hi, I couldn't find…
I couldn't find addscriptTablePush and addActionSchedulePush in the ANSI C source code. Should I have to add it by myself?
1 year 2 months ago
Hi, Those are not in all…
Those are not in all examples. Check the link that I shared.
