  2. DLMS Over LoraWan In Water Metering
DLMS over LoraWan in water metering
By labasvakaras, 15 July, 2025
Hello, wanted to ask a question, maybe you will have some insights.
We are trying to find a solution to launch DLMS over Lorawan. One thing is that our product is battery-powered water meter.
I have questions:
1. Maybe you have real life examples that this was done before?
2. time / Duty cycle - this time is very strict in lorawan, how it is possible to overcome this barrier when DLMS handshake takes up to 6-12 telegrams?
10 months 2 weeks ago
Hi, I believe that the best…
I believe that the best way to do this is if the meter uses push messages.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSPushSetup
DLMS and LoRa are not an easy combination.
labasvakaras
if i am using push setup and…
if i am using push setup and push messages, do I need to establish communication with AARQ/AARE messages?
Hi, AARQ/AARE are not used…
AARQ/AARE are not used with Push messages. The meter sends only the data, and a connection to the meter is not established.
  • Thu, 05/28/2026 - 13:16
    Gurux.DLMS.Net 9.0.2605.2801
  • Thu, 05/28/2026 - 13:14
    Gurux.DLMS.Python 1.0.198
  • Tue, 05/26/2026 - 11:37
    gurux.dlms.c 9.0.2605.2601
