  3. How To Limit Frame Size On Client Side?
how to limit frame size on client side?
By abk964 , 13 May, 2025
Gurux DLMS for ANSI C
Strange device works in "Director" only if checkbox "use frame size" is checked in "device properties".
How to set same option in C library?
Or is there other way to limit frame size?
1 year 5 months ago
Hi, Set maxInfoTX and…
Set maxInfoTX and maxInfoRX to the settings like this:
con.settings.maxInfoTX = 60;
abk964
1 year 5 months ago
Hi. Thanks. Have found my…
Hi.
Thanks. Have found my own mistake.
More detailed: any value of maxInfoTX and maxInfoRX except 128 will be passed in SNRM request.
Director sends 0x75 and 0x72 if checkbox "use frame size" is checked.
1 year 5 months ago
Hi, The use of frame size…
The use of frame size was used to fix the one-meter model issue. Don't use it if you don't have to.
The default values (128) are not sent in SNRM.
