  3. I Need Function of Below OBIS Code
I need function of below OBIS code
By sekar , 12 May, 2025
Gurux DLMS for ANSI C
please give document of below obis code
0,0,10,0,107,255
0,0,15,0,2,255
0,0,43,0,5,255
0,0,40,0,0,255
this OBIS required to firmware upgrade function
1 year 5 months ago
Hi, You can get the details…
You can get the details how to use image transfer from here:
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSImageTransfer
sekar
1 year 5 months ago
i am facing athentication…
i am facing athentication not done due to error read_write_denied can you guide and how to use invocation counter 0.0.43.1.5.255
1 year 5 months ago
Hi, You need to change the…
You need to change the authentication level and client address. The correct values should be on the meter documentation.
You can use the client example with arguments:
-C AuthenticationEncryption -v 0.0.43.1.5.255 - c METER_CLIENT_ADDRESS -a METER_AUTHENTICATION_LEVEL -B METER_BLOCK_CIPHER_KEY -A METER_AUTHENTICATION_KEY
The client example is here.
https://github.com/Gurux/GuruxDLMS.c/blob/44d7fe0dc5351f0656a931d362a1a…
