  3. Can I Add OBIS Codes and Functionality In GuruxDLMSServerExample For L1,L2,L3 For Voltage and Current Intead Use of Datacollector
Can I add OBIS codes and functionality in GuruxDLMSServerExample for L1,L2,L3 for Voltage and Current intead use of Datacollector
By VirendraN , 17 March, 2025
Gurux DLMS for ANSI C
I have build GuruxDLMSServerExample and GuruxDLMSClientExample. I am not using GuruxDLMSDataCollector. So can I add directly L1,L2,L3 for Voltage and Current related oBIS codes and its functionality in GuruxDLMSServerExample .I can see ActivePowerl1 added in server example
1 year 7 months ago
Hi, You need to add the the…
You need to add the the new object to ALL_OBJECTS list. After that you can see the object in the association view.
