  3. Dynamic Invocation Counter Management In Python Using Gurux GXDLMS Library
Dynamic Invocation Counter Management in Python Using Gurux GXDLMS Library
By KavyaYanamandra , 22 January, 2025
Gurux.Serial
I am working on a Python application using the Gurux GXDLMS library and need assistance with managing the invocation counter dynamically. Specifically, the counter value should be retrieved from the 16 association (logical name: 0.0.43.1.3.255) and then updated dynamically in the 48 association. The update can either use the exact value retrieved from the 16 association or apply an increment (e.g., adding +1 or +10 to the retrieved value). I would appreciate guidance or examples on how to implement this functionality effectively to ensure accurate and dynamic updates.
as this is code i wrote individually for 16 association and read the invocation counter from the meter:
# Initialize GXSerial connection
ser = GXSerial(port="COM3")
ser.__setBaudRate = int(9600)
ser.__setDataBits = 8
ser.__setStopBits = 1
ser.__setParity = 0
ser.open()
if ser.isOpen():
print("Serial port opened")
# Initialize settings and secure client
settings = GXSettings()
client = GXDLMSSecureClient()
# Assign the client and media to settings
settings.client = client
settings.media = ser
settings.trace = TraceLevel.INFO
settings.outputFile = "output.xml"
# Client properties
client.useLogicalNameReferencing= True
client.clientAddress=16
client.serverAddress=1
client.forAuthentication=Authentication.NONE
client.password=None
client.interfaceType=InterfaceType.HDLC
try:
# Initialize GXDLMSReader
reader = GXDLMSReader(client, ser, TraceLevel.INFO, invocationCounter=1)
reader.initializeConnection()
invocation_counter = GXDLMSData("0.0.43.1.3.255")
#invocation_counter = reader.invocationCounter
#invocation_counter += 10 # Or +1 as needed
invocation_counter = reader.read(invocation_counter,2)
# Use the updated invocation counter in subsequent requests
# reader.invocationCounter = invocation_counter
print("Updated Invocation Counter:", invocation_counter)
except Exception as ex:
print("Error during connection or reading:", ex)
finally:
ser.close()
and this is my settings of 48 association i gave in my application:
global disc
reader = None
reader= GXDLMSReader(settings.client, settings.media, settings.trace, settings.invocationCounter)
settings.client.ciphering.security= Security.AUTHENTICATION_ENCRYPTION
settings.client.ciphering.blockCipherKey = bytes(str(Entry4.get()), encoding="UTF-8")
settings.client.ciphering.authenticationKey = bytes(str(Entry5.get()), encoding='UTF-8')
settings.client.ciphering.dedicatedKey = bytes(str(Entry6.get()), encoding="UTF-8")
settings.client.password = str(Entry1.get())
settings.client.clientAddress = 48
settings.client.serverAddress = 1
settings.client.ciphering.Security = SecuritySuite.AES_GCM_128
settings.client.hdlcSettings.DEFAULT_WINDOWS_SIZE_TX = 1
settings.client.hdlcSettings.DEFAULT_WINDOWS_SIZE_RX = 1
settings.client.isAuthenticationRequired = SourceDiagnostic.AUTHENTICATION_REQUIRED
settings.client.authentication = Authentication.HIGH
Regards
Kavya
1 year 7 months ago
Hi, I can help you only with…
I can help you only with DLMS-specific questions. You need to check the client example. It does what you want to do.
  • addCaptureObject as Class ID=01 (Data) (not 03 (Register))
  • L+G E355 Load Control
