  3. Unable To Parse Billing Date Object Values When Reading Billing Profile.
Unable to parse Billing Date object values when reading Billing Profile.
By saraf_kshitiz , 9 January, 2025
Gurux DLMS for Android
Hi Mikko Kurumi Sir,
I'm unable to parse the hex values of Billing Date object when I'm reading Billing Profile from the meter.
I'm getting readings like this :-
Entries: 4/13
0.0.0.1.2.255 Billing Date
07 E9 01 06 01 12 1C 30 FF 80 00 00
07 E9 01 01 03 00 00 00 FF 80 00 00
Here's my code :-
        for (Object rows : cells) {
            sb = new StringBuilder();
            index = 0;
            for (Object cell : (Object[]) rows) {
                if (cell instanceof byte[]) {
                    sb.append(GXCommon.bytesToHex((byte[]) cell)).append(" | ");
                } else {
                    // If voltage attribute is there in the data
                    if (voltageFlag) {
                        if (index == voltageIndex) cell = getCorrectVoltage(cell);
                    sb.append(cell).append(" | ");
                index++;
            if (ObisCodesMapping.profileGenericScalers.contains(pg.getLogicalName()))
                processScalerPgData(sb);
            writeTraceCSV(sb.toString());
        showSnackBar(mContext);
I believe the if condition is running the statement : sb.append(GXCommon.bytesToHex((byte[]) cell)).append(" | ");
The bytes are converted to hex values, how do I parse this to datetime?
Waiting for your response.
Kshitiz.
1 year 9 months ago
Hi Kshitiz, The date-time…
Hi Kshitiz,
The date-time should be changed automatically if the capture object is a clock.
You can also change bytes to date-time like this:
GXDLMSClient.changeType((byte[])cell, ObjectType.DATE_TIME);
saraf_kshitiz
1 year 9 months ago
Hi Mikko Sir, Your given…
Hi Mikko Sir,
Your given code works fine and gives parsed datetime value for billing date.
You've been a great help and support.
There's just a minor update, DataType.DATETIME is used instead the parameter you gave. The code that worked for me looks like :-
String s1 = GXDLMSClient.changeType(
(byte[]) cell, DataType.DATETIME
).toString();
Log.d(TAG, "interateTableValues: s1: " + s1);
sb.append(s1).append(" | ");
// sb.append(GXCommon.bytesToHex((byte[]) cell)).append(" | ");
} else {
Kshitiz
