  3. When I Read Generic Profile I Getting Command From Client Can You Explain Command Format Each Byte
when i read generic profile i getting command from client can you explain command format each byte
By sekar , 11 December, 2024
Gurux DLMS for ANSI C
i using GXDLMSDriver has client and GuruxDLMSServerExample2 has server while reading generic profile, block load profile i am getting below Tx command from client can you explain frame byte by byte
TX: 7E A0 4C 03 41 98 2B 0C E6 E6 00 C0 01 C1 00 07 00 00 5E 5B 0A FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 0C 0B FF 00 00 00 FF 01 4A 00 09 0C 07 E8 0C 0C FF 00 00 00 FF 01 4A 00 01 00 7A 9C 7E
RX: 7E A0 12 41 03 B8 65 90 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
1 year 10 months ago
Hi, DLMS is a complicated…
DLMS is a complicated protocol and it's not possible to explain it shortly.
You can use DLMS translator to convert it XML.
https://www.gurux.fi/GuruxDLMSTranslator?translate=7EA04C0341982B0CE6E6…
Check also the FAQ.
sekar
while generic profile i am…
while generic profile i am facing error: invalid count what could be the issue...
Hi, The meter usually…
The meter usually returns invalid data if you get an invalid count error.
The reason might be anything. Can you read the values with the client example?
sekar
yes
yes
sekar
not able to read profile…
not able to read profile generic in client example also...
Hi, If you can't read the…
If you can't read the profile generics with the client example you have modified the source code of the client or the server. The GuruxDLMSServerExample2 example doesn't implement block load profile.
Check your changes.
