  3. Regarding INDIAN STANDARD
By ashusingh_007 , 25 November, 2024
I am trying to use the code provided to test my meter which is using indian standard. The code is working perfectly fine for without authentication. But i am unable to set the authentication type to MR using the code. Help me through it.
1 year 11 months ago
Hi, You need to change the…
You need to change the authentication level to Low and the client address to 32.
After that you can connect with MR.
