  3. GURUXDLMS Android Application Version 2.0.6
GURUXDLMS Android application version 2.0.6
By Kuntal , 4 July, 2024
Gurux DLMS for Android
We installed the DLMS Android application from https://github.com/Gurux/gurux.dlms.java, but some fields are not functioning and we are not receiving the exact procedures that are shown in the video after the application has run.
I have shared a screen shot of the issue that keeps coming up in the readDLMSPacket function successful = media.recieve(p);i am getting succeeded has false I am unable to get the response not even a single time, request is also not getting hit.
We have did the settings one more thing i want to add same settings we followed like we did in GXDLMSDirector.
Kuntal
2 years 4 months ago
Please share me if solutions…
Please share me if solutions any.
Hi, Check your settings. If…
Check your settings. If one of your settings is different than the meter expects you don't get the reply from the meter.
Then check your serial port settings. It's quite common that the baud-rate it wrong.
Kuntal
Hi sir, Connecting directly…
Hi sir,
Connecting directly from DLMS meter and GXDLMSDirector using optical probe works well without problem. Same optical probe is not working in the android application.
Optical probe information given below
Manufacturer info: L&T MPS: L&T MPS E-Meter USB optic port
Vendor: Future Technology Devices International Ltd ID:403
Product: F232 Serial (UART) IC ID:6001
Serial: L&T-MPS9
Chipset: FTD
Hi, Is the Interface type in…
Is the Interface type in GXLDMSDirector HDLC or HdlCModeE?
