  3. Meter Data Read and Write
Meter data Read and Write
By muhammad ahmed , 14 June, 2024
Hello we are creating an HES for DLMS electric meters so before starting we want to know that if all these things are possible are using Gurux ? if yes can you please describe the function which function of gurux we will use for each of the event
thank you
Need to read following data from meter:
- Load Profile
- ⁠Events
- ⁠Instantaneous data
- ⁠Daily Billing
- ⁠Monthly Billing
- ⁠SIM ID
Need to Read/Write following data from meter
- Update wakeup sim number
- Change meter status
- ⁠Optical Port
- ⁠Meter data sampling (like we need Loadprofile, events and instantaneous data after every X time)
- ⁠IP and Port
- ⁠Aux Relay
- ⁠Time of Use
- ⁠Load shedding
- ⁠Sanctioned Load
- ⁠Monthly Bill date time
- ⁠Time synchronization
2 years 4 months ago
Hi, All are supported. Read…
All are supported.
Read and write objects depend on the meter. I propose that you download GXDLMSDirector and play with it. It will help you to understand your DLMS meter.
Objects are described here:
https://www.gurux.fi/Gurux.DLMS.Objects
