  3. How Make Relay Connect Request To The Meter
How make relay connect request to the meter
By altumerc , 29 May, 2024
Gurux DLMS for Android
Hi there is no support for the method function in the app from where we can make relay connect or disconnect request
public void Method(GXDLMSObject it, int attributeIndex, object value, DataType type)
something like this is not present
Can you point out where the method is used so I can use it in the android accordingly
2 years 4 months ago
Hi, You can connect the…
You can connect the relay with Disconnect control.
GXDLMSDisconnectControl dc = new GXDLMSDisconnectControl();
byte[][] data = dc.remoteDisconnect(client);
or
byte[][] data = dc.remoteReconnect(client);
Send data to the meter using ReadDataBlock.
