  3. Firmware Upload Worked From Local System...Not Working On Server
Firmware upload worked from local system...Not working on Server
By midhun1212 , 18 March, 2024
Firmware upload worked from local system...Not working on Server .
ERROR io.undertow.request.handleThrowable -
org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.IllegalAccessError: tried to access class gurux.dlms.GXFCS16 from class
2 years 7 months ago
Hi, Are you implementing the…
Are you implementing the meter or reading the meter?
Is this happening only when you try to update the firmware?
