  3. Load Profile Extended Interval Status Bit Map
Load Profile Extended Interval Status bit map
By FredC , 28 February, 2024
Can anyone provide me or point to where I can find the bit mapping for the Load Profile Extended Interval Status bit map?
Fred
Note: This is what I have for the Standard (not the extended) Bit Map.
/* Profile Status
Bit Flag Description
7 PDN Power Down – This bit is set to indicate that a total power outage has been detected during the affected capture period.
6 - Reserved – This bit is always set to 0.
5 CAD Clock Adjusted – This bit is set when the clock has been adjusted more than the synchronization limit.
4 - Reserved – This bit is always set to 0.
3 DST Daylight Saving – This bit indicates whether or not the daylight saving time is active. The bit is set when DST is active.
2 DNV Data Not Valid – Indicates that the current entry should not be used for billing purposes without further validation.
1 CIV Clock Invalid – The power reserve of the calendar clock has been exhausted and the time is declared invalid. This is accompanied by the DNV flag.
0 ERR Critical Error – A serious error has occurred. This is accompanied by the DNV flag.
2 years 6 months ago
Hi, I believe that this…
I believe that this might be saved for the data object, but I believe that this is defined on the meter documentation.
In general DLMS standards don't define the content of the data. This means that each manufacturer can use different enum values. This means that it's not possible to show a description of each bit and you can see only one and zero values without textual description.
