  3. Problem With Download Agent
Problem with download Agent
By Agg , 27 February, 2024
Gurux.DLMS.AMI
Hi,I cannot download the proxy when compiling the program using source code, and it shows that there is nothing at this address. However, it can be downloaded when running through Docker. So how do I download the proxy under source code compilation?
2 years 8 months ago
Hi, I'm sorry, but what do…
I'm sorry, but what do you mean by proxy? If you are starting the Gurux.DLMS.AMI from the source code the URL is different than with proxy.
You need to use URL like this with source code:
https://{YOUR_URL}:44338
Agg
sorry,I made a mistake in…
sorry,I made a mistake in expressing myself. It's not proxy, it's agent. As described in the title.i can't download the agent by using the AMI
Hi, I did try this, but it…
I did try this, but it worked without problems. I'll verify that we are doing the same steps.
1. Select "Agents".
2. Select "Add".
3. Select "Download the agent"
If we are doing the same steps what operating system you are using (Windows/Linux)?
Agg
Yes,we do the same thing. I…
Yes,we do the same thing. I do this on windows. A few days ago, I was able to download it. But after a few days, when I tried to run AMI again, I couldn't download it. Then I obtained the source code from GitHub again for compilation, but it still doesn't work
