  3. Reading OBIS Code 1.8.0 Register Name Difference
By Burger , 26 February, 2024
I try to read register with address 1.8.0 because according my research on internet 1.1.1.8.0.255 refers to total active import energy.
But according to returned message from Gurux and 62056-61, 1.8.0 is said to be Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0.
Do these two description mean the same or if not what causes the difference?
Burger
2 years 8 months ago
1.8.0 Total active import…
1.8.0 Total active import energy
Hi, In DLMS standard 1.1.1.8…
In DLMS standard 1.1.1.8.0.255 means Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0. You need to ask the meter vendor what is counted for total active import energy in this meter.
I believe that the meter manufacturer is using a shorter description and they mean the same, but you need to verify this from the meter vendor.
