  2. Every Time Simulator Gives Client Address: 16 Without Authentication.
Every time simulator gives Client address: 16 Without authentication.
Profile picture for user satishchauhan671
By satishchauhan671 , 19 February, 2024
Dear Sir,
I am trying to create a high authentication (US) template. Template is created successfully but when i am connecting that template connects only without authentication.
I am using shared format below to create a single phase template for high association.
-S COM3 -o hpl_singlePh.xml -d India -t Verbose -i HDLC -c 32 -a High -P 1111111100000000 -C AuthenticationEncryption -A 0000000000000000 -B 0000000000000000 -v 0.0.43.1.2.255 -T HPL72998
For run template
-p 4060 -x hpl_singlePh.xml -N 10 -d India -t Verbose -i HDLC -a High -c 48 -P 1111111100000000 -C AuthenticationEncryption -A 0000000000000000 -B 0000000000000000 -v 0.0.43.1.3.255 -T HPL72998
After run getting
DLMS HDLC Logical Name simulator start in ports 4060-4069.
Server address: 1
Associations:
Conformance:
[GET]
MaxReceivePduSize: 550 MaxSendPduSize: 550
Client address: 0 Without authentication.
Conformance:
MaxReceivePduSize: 1024 MaxSendPduSize: 0
Conformance:
Conformance:
I want connection with high authentication. I am new please help me for fix this.
Satish Chauhan.
satishchauhan671
2 years 3 months ago
Dear Sir, Please help for…
Dear Sir,
Please help for how to run template for high authentication. I have change clientSAP in xml file also. From 0 to 16, 32 and 48. But after change value of clientSAP it gives invalid authentication tag.
Satish Chauhan.
Hi Satish, There is…
Hi Satish,
There is something wrong with your simulator template. In your command line parameters, you use High-level authentication, but when you start the simulator it uses None (public) authentication. Can you connect with GXDLMSDirector using High level association for this meter?
