  3. Starting With Gurux DLMS For Java
Starting with Gurux DLMS for Java
Profile picture for user alfathaff
By alfathaff , 4 January, 2024
First of all, sorry if this same query has been uploaded on the forum.
I have tried running Gurux client and Gurux server using Maven and Eclips, but it always gives an error like this:
The declared package "gurux.dlms.xmlClient" does not match the expected package "main.java.gurux.dlms.xmlClient"
BAUDRATE_9600 cannot be resolved or is not a field
BAUDRATE_600 cannot be resolved or is not a field
BAUDRATE_300 cannot be resolved or is not a field
AccessMode cannot be resolved to a variable
AccessMode cannot be resolved to a type
Resource:
/gurux.dlms.xmlClient/src/main/java/gurux/dlms/xmlClient/GXDLMSReader.java
/gurux.dlms.xmlClient/src/main/java/gurux/dlms/xmlClient/Program.java
/gurux.dlms.xmlClient/src/main/java/gurux/dlms/xmlClient/Settings.java
/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java
Looking forward to a quick response.
2 years 10 months ago
Hi, Have you import the…
Have you import the project as a Maven project?
1. Select "Import"
2. Select Maven and "Existing Maven Project"
3. Press Next.
4. Select Root Directory.
5. Press Finish.
Now maven will download missing projects.
You can also run:
mvn clean package
This will get all the needed packages and build your project.
alfathaff
Yes, I have tried using…
Yes, I have tried using Eclipse with the steps above, and I also tried mvn clean package, the same error came out:
[INFO] 10 errors
[INFO] -------------------------------------------------------------
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 3.018 s
[INFO] Finished at: 2024-01-04T21:08:36+07:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.11.0:compile (default-compile) on project gurux.dlms.server.example.java: Compilation failure: Compilation failure:
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[1648,15] cannot find symbol
[ERROR] symbol: class AccessMode
[ERROR] location: class gurux.dlms.server.example.GXDLMSBase
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[544,28] cannot find symbol
[ERROR] symbol: variable AccessMode
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[579,24] cannot find symbol
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[731,45] cannot find symbol
[ERROR] symbol: variable BAUDRATE_9600
[ERROR] location: class gurux.io.BaudRate
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[732,44] cannot find symbol
[ERROR] symbol: variable BAUDRATE_300
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[826,42] cannot find symbol
[ERROR] symbol: variable BAUDRATE_600
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[1651,20] cannot find symbol
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[1656,24] cannot find symbol
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[1658,20] cannot find symbol
[ERROR] /C:/Users/ASUS/Desktop/Project PLN/DLMS/gurux.dlms.java-master/gurux.dlms.java-master/gurux.dlms.server.example.java/src/gurux/dlms/server/example/GXDLMSBase.java:[1661,16] cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Hi, It seems that there were…
It seems that there were old version from the server example in Github. Get the latest version and let me know if you have problems.
alfathaff
Hello, I downloaded the…
Hello, I downloaded the latest version from GitHub and ran it without encountering any issues. Thank you very much!
