  3. Creating Next Frame Request From Last Hex Response Is Not Working(receiverReady)
Creating Next Frame request from last hex response is not working(receiverReady)
By sethi.nitin9@g… , 11 December, 2023
Hi Kurumi,
I have tried checking and generating next request from previous frame if data is there, but it is not working as per expectation and throwing Invalid GLO Command exception.
isMoreData Exits is giving true but when I'm generating request it is throwing error:
Below is the code I have used:
this.hexData = "000100010030021BCC82021730000002C92F57250F2EF8065442022FD2EFDB07BBB5B2A53807079CCCC8C79950991FFA9E7AA819082E176282983D3D0AAFF114C18AB44C78C05EE885AAC4315ECC1F7588BEC19A9CEDD5AAE5D46B8A05D4EA88D89CA2ABC5504074018882D464CD9FBDA934B9C93D1C535AB25B630F606D8A96F1B3BF35D4D61D01A7982D9FBF861222BB3AEA5A98EED2334F67E9750ADD90D786907996EB7EEDB1997BFF68CD2761217F9AA8FE860F249BA73EAAFA6C632690999F924EE31AA202E96A4ED10836B51A60214DB0ABA9D632E258791E97FB04EE86A414177A7D1A135600D28C2A7DC7BE5F18223039F250DD6E622E56A94B25CE37F31BCD1D1D4914762E829B89D80660779734C5B9BFB35BF5DA831AF326ED796C46387FAFC29CBC31C6B289DC5D57BEEF92E3C9D228DF641E368B55B95C6E161FBB29CA2E64CCC0335ED10930922B6997372AAD366D1244BDD24343E642C1B617046102747DD9A83F73A6C018746EADEBD7F089231296AD8F5A30FEB8576AEF659AF73843AD7029E9038F98489495E79F7E55BC8474CC0A20459DF7FF82E5BA407DF7B111C37BDFCAFD31C7888477D1F24660C42A1B6223A15185F95003A8777FCB84DFB25711517A37BBDB90E5D249040AA5F70F99F44651BEC8718E5DCCD4601A8A52544F187AED40B2FB1A5DAA2D0EC57EA5B8CB0DF33EDD9A3043391C1463322EADEC14F88B00EAA7F9804E944F589F16D3C72FADADA1D03B38519CAF8F604AB7";
GXDLMSSecureClient client = new GXDLMSSecureClient();
client.setServerAddress(1);
client.setClientAddress(48);
client.getCiphering().setInvocationCounter(12544);
client.setAuthentication(Authentication.HIGH);
client.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
client.setInterfaceType(InterfaceType.WRAPPER);
client.getCiphering().setSystemTitle("HPL20215".getBytes("ASCII"));
client.setServerSystemTitle(GXCommon.hexToBytes("48504C00003D57F7"));
client.getCiphering().setBlockCipherKey("1234ABCD1234ABCD".getBytes("ASCII"));
client.getCiphering().setAuthenticationKey("1234ABCD1234ABCD".getBytes("ASCII"));
client.setPassword("bbbbbbbbbbbbbbbb".getBytes("ASCII"));
byte data[] = GXCommon.hexToBytes(this.hexData);
client.getData(data, reply);
boolean isMoreData = reply.isMoreData();
System.out.println("Is More Data Available: "+isMoreData);
byte nextBlock[] = client.receiverReady(reply);
System.out.println("Next Frame: "+ GXCommon.bytesToHex(nextBlock));
Error:
java.lang.RuntimeException: Invalid GLO command.
at com.global.meter.gurux.dlms.GXDLMSClient.receiverReady(GXDLMSClient.java:3049)
2 years 11 months ago
Hi, You try to send meter…
You try to send meter GetResponse using the client. That is not how it's designed.
What do you want to do?
sethi.nitin9@g…
I want to read the next…
I want to read the next datablock from meter as all data is not fit to a single block.
As I have checked more data is coming true, but next frame is not generating successfully. I need to send that request using rest api.
Please guide me for this.
Hi, The framework generates…
The framework generates the needed reply automatically. You haven't shown what kind of read request you have generated and where the reply is coming from.
Ciphering is not just sending bytes. There is an invocation counter that needs to be updated after each request.
