  3. Waveshare Ethernet Rs485
Waveshare ethernet rs485
By khana , 6 December, 2023
Gurux.Net
Hello Dear,
How to read data using waveshare gateway.
May i need to use MQTT in this.
2 years 11 months ago
Hi, Waveshare gateway doesn…
Waveshare gateway doesn't support MQTT so you need e.g. Raspberry PI to handle MQTT messages and then send them to the converter as raw data.
khana
Can i read dlms meter data…
Can i read dlms meter data using this gateway.
Is this possible to read directly from meter using this gateway?
2 years 10 months ago
Hi, You can use this module…
You can use this module to extend RS-232 connection to TCP/IP connection.
If you can establish the TCP/IP connection for this module you should be able to read your meter.
