  3. Convert Read Data To String or JSON Format
Convert read data to String or JSON format
By mightyChamp , 19 September, 2023
I need to read specific Obis codes and convert their values to an JSON Object.
Server Sends Obis code and Object type like Data, Register or Profile generic.
I am reading like this:
GXDLMSRegister d = new GXDLMSRegister(obStruct.obis_code);
reader.read(d,3);
reader.read(d,2);
GXDLMSProfileGeneric d = new GXDLMSProfileGeneric(obStruct.obis_code);
reader.read(d,3);
reader.read(d,4);
reader.read(d,5);
reader.read(d,6);
reader.read(d,7);
reader.read(d,8);
Then Now Convert Obtain value to String or JSON.
Please suggest best way to convert those values to JSON or String.
Thank You
3 years 1 month ago
Hi, You can save values in…
You can save values in XML using the save method of GXDLMSObjectCollection. If you want to convert them to string, you need to check printValue and printData. I believe those methods will help you.
https://github.com/Gurux/gurux.dlms.java/blob/95e18ad954b68ad8be058c9f6…
