  3. TCP/IP Connection On HXF300
TCP/IP connection on HXF300
By zeus8497st , 11 September, 2023
Gurux.Net
Hi Gurux hope you're doing.
i need your guidance, i'm trying to gain access to my meter remotely over tcp/Ip by using the DLMSDirector .
i know all required parameters and security that i already use in local mode .
i have selected the NET " media" and put the IP address "Host name" and port of my meter.
but the meter didnt reply, of course we are in the same network . It would great if you give us a little help . thanks in advance.
log
12:35:04 Initializing Network connection.
12:35:06 Send AARQ request.
00 01 00 01 00 11 00 4C 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 0D 18 76 4D 6C 22 2E 36 3C 01 0A 48 04 4B 30 2D BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF
12:35:11 Data send failed. Try to resend 1/3
12:35:16 Data send failed. Try to resend 2/3
12:35:21 Failed to receive reply from the device in given time.
à GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[][] data, String text, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
12:40:55 Initializing Network connection.
System.Net.Sockets.SocketException (0x80004005): Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée
à GXDLMSDirector.GXDLMSCommunicator.InitNet()
12:41:04 Initializing Network connection.
12:41:41 Initializing Network connection.
12:41:42 Send AARQ request.
00 01 00 01 00 11 00 4C 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 5D 39 69 22 21 60 5A 06 4D 5A 2F 38 4B 0F 2D 04 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF
12:41:47 Data send failed. Try to resend 1/3
12:41:52 Data send failed. Try to resend 2/3
12:41:57 Failed to receive reply from the device in given time.
12:48:20 Initializing Network connection.
12:48:21 Send AARQ request.
00 01 00 01 00 11 00 4C 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 6B 5D 12 5C 75 31 3B 79 54 16 19 3D 11 6F 35 4E BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF
12:48:26 Data send failed. Try to resend 1/3
12:48:31 Data send failed. Try to resend 2/3
12:48:36 Failed to receive reply from the device in given time.
zeus8497st
3 years ago
file
file
3 years ago
Hi, One of your parameters…
One of your parameters is different from what the meter expects. Check the meter manual what server and client addresses you should use and if the connection is ciphered.
