  3. Simulator - Display Not All Objects
Simulator - display not all objects
By JavierDiaz , 18 August, 2023
Gurux.Net
I have an xml file with Date and Association objects.
I run the simulator:
-p 1000 -x sim.xml -t Verbose -N 1 -a Higt -P 1234567812345678 -c 48 -s 1 -l 0
Log:
DLMS HDLC Logical Name simulator start in ports 1000-1000.
Waiting 00:04:47 before next execution.
Server address: 1
Associations:
Client address: 16 Without authentication.
Conformance:
Write, BlockTransferWithSetOrWrite
MaxReceivePduSize: 1024 MaxSendPduSize: 1024
Client address: 48 High authentication, password 1234567812345678
Conformance:
ReservedZero, GeneralBlockTransfer, Read, Write, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite
Security suite: Suite0
Security policy: None
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Broadcast block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
I add the device to Director.
I click Connect, but only 2 objects are displayed in the tree - 0.0.40.0.0.255.
Please tell me what could be wrong.
3 years ago
Hi, You can see all the…
You can see all the objects that are in the association view. Different association views can have different objects. I believe that you have connected without authentication. Try to change authentication to High and try connect again. You need to refresh the association view by selecting "File" and "Refresh".
