  3. Obsolete Warnings .NET VS2022
Obsolete warnings .NET VS2022
By DuddyS , 25 July, 2023
Gurux.Net
Inspecting our application warnings we see a lot of 'obsolete' messages which appear to be related to Gurux components, e.g.
CS0618 'GXDLMSLimits' is obsolete: 'Use GXHdlcSettings instead.' Gurux.DLMS.Net (net60) C:\Projects\VisualStudio2022\manulyapp\Gurux.DLMS.Net\GXDLMSSettings.cs 382
CS0618 'GXDLMSServer.PostGet(ValueEventArgs[])' is obsolete: 'Use PostRead instead.' Gurux.DLMS.Net (net60) C:\Projects\VisualStudio2022\manulyapp\Gurux.DLMS.Net\Objects\GXDLMSCompactData.cs 618
SYSLIB0021 'MD5CryptoServiceProvider' is obsolete: 'Derived cryptographic types are obsolete. Use the Create method on the base type instead.' Gurux.DLMS.Net (net60) C:\Projects\VisualStudio2022\manulyapp\Gurux.DLMS.Net\ManufacturerSettings\GXManufacturerCollection.cs 156
Could you provide any insight as these appear to be related to the library, rather than our source code?
3 years 2 months ago
Hi, GXHdlcSettings and…
GXHdlcSettings and PostGet are old functionality and will be removed at some point after our clients are not using them anymore.
