  3. ANR In Gurux.dlms.android
ANR in gurux.dlms.android
By mightyChamp , 18 July, 2023
Gurux DLMS for Android
We are trying to Get Association view from the meter, But when we call the method refresh(), It goes in the Application Not responding (ANR).
Below is the error:
PID: 11082
Reason: MainThread worked timeout
ErrorId: c6529571-0055-46ce-be1d-0bf290c0b905
Frozen: false
Load: 5.08 / 3.75 / 3.4
3 years 3 months ago
Hi, Can you read the meter…
Can you read the meter with GXDLMSDirector? If you can, add a hex trace here and I'll check what might be the problem.
What Android version you are using?
mightyChamp
Hi, Yes, We can read the…
Yes, We can read the meter with GXDLMSDirector.
We will share a hex trace soon.
The issues is in Android 13, We have checked in Android 12 it's working.
mightyChamp
We are unable to get the…
We are unable to get the trace, because it hangs and goes in ANR,
The issues is in Android 13.
Looking for your support.
Hi, Can you get the hex…
Can you get the hex trace with GXDLMSDirector so we can try to solve this?
I'll check this also with Android 13 after I have the hex trace.
mightyChamp
Please find the below hex…
Please find the below hex trace from Android Studio
2023-07-27 16:40:27.183 21895-21895 System.out gurux.dlms.android I <- 16:40:27.176 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
2023-07-27 16:40:27.410 21895-21895 System.out gurux.dlms.android I -> 16:40:27.385 7E A8 89 41 03 52 CB AC E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 03 F9 01 4D 02 04 12 00 01 11 00 09 06 00 00 00 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 00 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 AD 05 7E
2023-07-27 16:40:27.422 21895-21895 System.out gurux.dlms.android I <- 16:40:27.410 7E A0 07 03 41 51 44 81 7E
2023-07-27 16:40:27.622 21895-21895 System.out gurux.dlms.android I -> 16:40:27.593 7E A8 89 41 03 54 FD C9 00 09 06 00 00 5E 5B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 5B 0C FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 27 E1 7E
2023-07-27 16:40:27.637 21895-21895 System.out gurux.dlms.android I <- 16:40:27.622 7E A0 07 03 41 71 46 A0 7E
2023-07-27 16:40:27.850 21895-21895 System.out gurux.dlms.android I -> 16:40:27.817 7E A8 89 41 03 56 EF EA 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 00 FF 02 02 64 56 7E
2023-07-27 16:40:27.871 21895-21895 System.out gurux.dlms.android I <- 16:40:27.850 7E A0 07 03 41 91 48 47 7E
2023-07-27 16:40:28.078 21895-21895 System.out gurux.dlms.android I -> 16:40:28.040 7E A8 89 41 03 58 91 03 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 0E AD 7E
2023-07-27 16:40:28.102 21895-21895 System.out gurux.dlms.android I <- 16:40:28.078 7E A0 07 03 41 B1 4A 66 7E
2023-07-27 16:40:28.321 21895-21895 System.out gurux.dlms.android I -> 16:40:28.280 7E A8 89 41 03 5A 83 20 11 00 09 06 00 00 60 0B 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 E4 86 7E
2023-07-27 16:40:28.327 21895-21909 ux.dlms.android gurux.dlms.android I ThreadFlipBegin blocked for 12.434ms
2023-07-27 16:40:28.352 21895-21895 System.out gurux.dlms.android I <- 16:40:28.321 7E A0 07 03 41 D1 4C 05 7E
2023-07-27 16:40:28.357 21895-21911 System gurux.dlms.android W A resource failed to call close.
2023-07-27 16:40:28.580 21895-21895 System.out gurux.dlms.android I -> 16:40:28.536 7E A8 89 41 03 5C B5 45 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 00 FF 02 CC 0B 7E
2023-07-27 16:40:28.610 21895-21895 System.out gurux.dlms.android I <- 16:40:28.580 7E A0 07 03 41 F1 4E 24 7E
2023-07-27 16:40:28.682 21895-22122 Quality gurux.dlms.android I stackInfo :----- pid 21895 at 2023-07-27 16:40:28.676 -----;Cmd line: gurux.dlms.android;"main" prio=5 tid=2 TIMED_WAITING sysTid=21895; at java.lang.Object.wait(Native Method); at java.lang.Object.wait(Object.java:442); at gurux.common.AutoResetEvent.waitOne(AutoResetEvent.java:94); at gurux.common.GXSynchronousMediaBase.findData(GXSynchronousMediaBase.java:378); at gurux.common.GXSynchronousMediaBase.receive(GXSynchronousMediaBase.java:460); at gurux.serial.GXSerial.receive(GXSerial.java:1097); at gurux.dlms.android.ui.main.MainFragment.readDLMSPacket(MainFragment.java:695); at gurux.dlms.android.ui.main.MainFragment.readDataBlock(MainFragment.java:764); at gurux.dlms.android.ui.main.MainFragment.readDataBlock(MainFragment.java:746); at gurux.dlms.android.ui.main.MainFragment.readAssociationView(MainFragment.java:441); at gurux.dlms.android.ui.main.MainFragment.lambda$onCreateView$9$gurux-dlms-android-ui-main-MainFragment(MainFragment.java:222); at gurux.dlms.android.ui.main.MainFragment$$ExternalSyntheticLambda6.run(Unknown Source:2); at android.os.Handler.handleCallback(Handler.java:942); at android.os.Handler.dispatchMessage(Handler.java:99); at android.os.Looper.loopOnce(Looper.java:240); at android.os.Looper.loop(Looper.java:351); at android.app.ActivityThread.main(ActivityThread.java:8422); at java.lang.reflect.Method.invoke(Native Method); at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:584); at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1013);
2023-07-27 16:40:28.840 21895-21895 System.out gurux.dlms.android I -> 16:40:28.792 7E A8 89 41 03 5E A7 66 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 08 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 80 96 80 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 A7 A4 7E
2023-07-27 16:40:28.874 21895-21895 System.out gurux.dlms.android I <- 16:40:28.840 7E A0 07 03 41 11 40 C3 7E
2023-07-27 16:40:29.106 21895-21895 System.out gurux.dlms.android I -> 16:40:29.048 7E A8 89 41 03 50 D9 8F 01 11 00 09 06 00 80 8C 80 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 80 98 80 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 80 99 80 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 80 9A 80 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 A5 B4 7E
2023-07-27 16:40:29.143 21895-21895 System.out gurux.dlms.android I <- 16:40:29.107 7E A0 07 03 41 31 42 E2 7E
2023-07-27 16:40:29.240 21895-21895 System.out gurux.dlms.android I -> 16:40:29.192 7E A0 11 41 03 52 FC FD 03 0F 02 16 01 00 01 00 B1 72 7E
2023-07-27 16:40:29.277 21895-21895 System.out gurux.dlms.android I <- 16:40:29.240 7E A0 13 03 41 54 A4 67 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
2023-07-27 16:40:29.510 21895-21895 System.out gurux.dlms.android I -> 16:40:29.463 7E A8 89 41 03 74 FF E8 E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 03 E3 02 04 12 00 01 11 00 09 06 00 80 8D 80 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 00 01 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 00 00 5E 5B 08 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 E9 C4 7E
2023-07-27 16:40:29.551 21895-21895 System.out gurux.dlms.android I <- 16:40:29.511 7E A0 07 03 41 71 46 A0 7E
2023-07-27 16:40:29.785 21895-21895 System.out gurux.dlms.android I -> 16:40:29.734 7E A8 89 41 03 76 ED CB 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 03 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 09 07 00 D2 C1 7E
2023-07-27 16:40:29.824 21895-21895 System.out gurux.dlms.android I <- 16:40:29.785 7E A0 07 03 41 91 48 47 7E
2023-07-27 16:40:30.064 21895-21895 System.out gurux.dlms.android I -> 16:40:30.006 7E A8 89 41 03 78 93 22 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 41 FC 7E
2023-07-27 16:40:30.106 21895-21895 System.out gurux.dlms.android I <- 16:40:30.064 7E A0 07 03 41 B1 4A 66 7E
2023-07-27 16:40:30.185 21895-22122 Quality gurux.dlms.android I stackInfo :----- pid 21895 at 2023-07-27 16:40:30.183 -----;Cmd line: gurux.dlms.android;"main" prio=5 tid=2 TIMED_WAITING sysTid=21895; at java.lang.Object.wait(Native Method); at java.lang.Object.wait(Object.java:442); at gurux.common.AutoResetEvent.waitOne(AutoResetEvent.java:94); at gurux.common.GXSynchronousMediaBase.findData(GXSynchronousMediaBase.java:378); at gurux.common.GXSynchronousMediaBase.receive(GXSynchronousMediaBase.java:460); at gurux.serial.GXSerial.receive(GXSerial.java:1097); at gurux.dlms.android.ui.main.MainFragment.readDLMSPacket(MainFragment.java:695); at gurux.dlms.android.ui.main.MainFragment.readDataBlock(MainFragment.java:764); at gurux.dlms.android.ui.main.MainFragment.readDataBlock(MainFragment.java:746); at gurux.dlms.android.ui.main.MainFragment.readAssociationView(MainFragment.java:441); at gurux.dlms.android.ui.main.MainFragment.lambda$onCreateView$9$gurux-dlms-android-ui-main-MainFragment(MainFragment.java:222); at gurux.dlms.android.ui.main.MainFragment$$ExternalSyntheticLambda6.run(Unknown Source:2); at android.os.Handler.handleCallback(Handler.java:942); at android.os.Handler.dispatchMessage(Handler.java:99); at android.os.Looper.loopOnce(Looper.java:240); at android.os.Looper.loop(Looper.java:351); at android.app.ActivityThread.main(ActivityThread.java:8422); at java.lang.reflect.Method.invoke(Native Method); at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:584); at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1013);
2023-07-27 16:40:30.337 21895-21895 System.out gurux.dlms.android I -> 16:40:30.277 7E A8 89 41 03 7A 81 01 03 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 0D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 FD ED 7E
2023-07-27 16:40:30.379 21895-21895 System.out gurux.dlms.android I <- 16:40:30.337 7E A0 07 03 41 D1 4C 05 7E
2023-07-27 16:40:30.610 21895-21895 System.out gurux.dlms.android I -> 16:40:30.549 7E A8 89 41 03 7C B7 64 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 0E 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 20 07 00 9D 14 7E
2023-07-27 16:40:30.657 21895-21895 System.out gurux.dlms.android I <- 16:40:30.611 7E A0 07 03 41 F1 4E 24 7E
2023-07-27 16:40:30.904 21895-21895 System.out gurux.dlms.android I -> 16:40:30.837 7E A8 89 41 03 7E A5 47 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 21 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 33 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 48 83 7E
2023-07-27 16:40:30.953 21895-21895 System.out gurux.dlms.android I <- 16:40:30.905 7E A0 07 03 41 11 40 C3 7E
2023-07-27 16:40:30.963 21895-21909 ux.dlms.android gurux.dlms.android I ThreadFlipBegin blocked for 13.626ms
2023-07-27 16:40:30.964 21895-21895 ux.dlms.android gurux.dlms.android I IncrementDisableThreadFlip blocked for 10.731ms
2023-07-27 16:40:31.210 21895-21895 System.out gurux.dlms.android I -> 16:40:31.141 7E A8 89 41 03 70 DB AE 03 00 02 04 12 00 03 11 00 09 06 01 00 34 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 35 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 47 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 B6 2C 7E
2023-07-27 16:40:31.261 21895-21895 System.out gurux.dlms.android I <- 16:40:31.210 7E A0 07 03 41 31 42 E2 7E
2023-07-27 16:40:31.384 21895-22062 Quality gurux.dlms.android I JankCountInfo: gurux.dlms.android.MainActivity basic:0-0-0 action:6 data:0-3 type:2 stage:1-0-0 action:10 data:0-0 type:2 stage:1-0-0 action:13 data:0-0 type:2 stage:8-0-0 action:16 data:0-2
2023-07-27 16:40:31.499 21895-21895 System.out gurux.dlms.android I -> 16:40:31.427 7E A0 7B 41 03 72 B4 99 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 48 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 01 00 49 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 DB C1 7E
2023-07-27 16:40:31.554 21895-21895 System.out gurux.dlms.android I <- 16:40:31.499 7E A0 13 03 41 56 B6 44 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
2023-07-27 16:40:31.823 21895-21895 System.out gurux.dlms.android I -> 16:40:31.749 7E A8 89 41 03 94 F1 0F E6 E7 00 C4 02 C1 00 00 00 00 03 00 82 03 F6 02 04 12 00 04 11 00 09 06 01 00 01 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 04 11 00 09 06 01 00 09 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 0F B4 7E
2023-07-27 16:40:31.882 21895-21895 System.out gurux.dlms.android I <- 16:40:31.824 7E A0 07 03 41 71 46 A0 7E
2023-07-27 16:40:32.132 21895-21895 System.out gurux.dlms.android I -> 16:40:32.051 7E A8 89 41 03 96 E3 2C 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 BF EC 7E
2023-07-27 16:40:32.193 21895-21895 System.out gurux.dlms.android I <- 16:40:32.133 7E A0 07 03 41 91 48 47 7E
2023-07-27 16:40:32.453 21895-21895 System.out gurux.dlms.android I -> 16:40:32.370 7E A8 89 41 03 98 9D C5 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 05 10 7E
2023-07-27 16:40:32.521 21895-21895 System.out gurux.dlms.android I <- 16:40:32.453 7E A0 07 03 41 B1 4A 66 7E
2023-07-27 16:40:32.778 21895-21895 System.out gurux.dlms.android I -> 16:40:32.690 7E A8 89 41 03 9A 8F E6 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 04 FF 02 02 60 2B 7E
2023-07-27 16:40:32.849 21895-21895 System.out gurux.dlms.android I <- 16:40:32.778 7E A0 07 03 41 D1 4C 05 7E
2023-07-27 16:40:33.116 21895-21895 System.out gurux.dlms.android I -> 16:40:33.025 7E A8 89 41 03 9C B9 83 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 63 62 05 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 14 7A 7E
2023-07-27 16:40:33.186 21895-21895 System.out gurux.dlms.android I <- 16:40:33.117 7E A0 07 03 41 F1 4E 24 7E
2023-07-27 16:40:33.454 21895-21895 System.out gurux.dlms.android I -> 16:40:33.361 7E A8 89 41 03 9E AB A0 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 00 00 5E 5B 0A FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 14 48 7E
2023-07-27 16:40:33.527 21895-21895 System.out gurux.dlms.android I <- 16:40:33.455 7E A0 07 03 41 11 40 C3 7E
2023-07-27 16:40:33.787 21895-21895 System.out gurux.dlms.android I -> 16:40:33.696 7E A8 89 41 03 90 D5 49 01 09 06 01 00 5E 5B 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 3E 91 7E
2023-07-27 16:40:33.862 21895-21895 System.out gurux.dlms.android I <- 16:40:33.787 7E A0 07 03 41 31 42 E2 7E
2023-07-27 16:40:34.126 21895-21895 System.out gurux.dlms.android I -> 16:40:34.031 7E A8 89 41 03 92 C7 6A 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 35 1B 7E
2023-07-27 16:40:34.206 21895-21895 System.out gurux.dlms.android I <- 16:40:34.126 7E A0 07 03 41 51 44 81 7E
2023-07-27 16:40:34.346 21895-21895 System.out gurux.dlms.android I -> 16:40:34.256 7E A0 0E 41 03 94 9E 2F 02 0F 02 03 00 D1 B7 7E
2023-07-27 16:40:34.426 21895-21895 System.out gurux.dlms.android I <- 16:40:34.347 7E A0 13 03 41 78 CA 8C E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
2023-07-27 16:40:34.730 21895-21895 System.out gurux.dlms.android I -> 16:40:34.624 7E A8 89 41 03 B6 E1 0D E6 E7 00 C4 02 C1 00 00 00 00 04 00 82 03 FC 02 04 12 00 07 11 01 09 06 01 00 5E 5B 05 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 06 FF 02 02 01 08 02 03 0F 01 16 B8 86 7E
2023-07-27 16:40:34.749 21895-21909 ux.dlms.android gurux.dlms.android I ThreadFlipBegin blocked for 13.491ms
2023-07-27 16:40:34.816 21895-21895 System.out gurux.dlms.android I <- 16:40:34.731 7E A0 07 03 41 91 48 47 7E
2023-07-27 16:40:35.091 21895-21895 System.out gurux.dlms.android I -> 16:40:34.990 7E A8 89 41 03 B8 9F E4 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 5E 5B 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 D6 70 7E
2023-07-27 16:40:35.175 21895-21895 System.out gurux.dlms.android I <- 16:40:35.091 7E A0 07 03 41 B1 4A 66 7E
2023-07-27 16:40:35.472 21895-21895 System.out gurux.dlms.android I -> 16:40:35.359 7E A8 89 41 03 BA 8D C7 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 62 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 63 01 C9 46 7E
2023-07-27 16:40:35.562 21895-21895 System.out gurux.dlms.android I <- 16:40:35.472 7E A0 07 03 41 D1 4C 05 7E
2023-07-27 16:40:35.852 21895-21895 System.out gurux.dlms.android I -> 16:40:35.742 7E A8 89 41 03 BC BB A2 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 DD C0 7E
2023-07-27 16:40:35.945 21895-21895 System.out gurux.dlms.android I <- 16:40:35.852 7E A0 07 03 41 F1 4E 24 7E
2023-07-27 16:40:36.238 21895-21895 System.out gurux.dlms.android I -> 16:40:36.125 7E A8 89 41 03 BE A9 81 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 00 02 02 0F 02 03 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 03 00 02 F3 1A 7E
2023-07-27 16:40:36.334 21895-21895 System.out gurux.dlms.android I <- 16:40:36.239 7E A0 07 03 41 11 40 C3 7E
2023-07-27 16:40:36.602 21895-21909 ux.dlms.android gurux.dlms.android I ThreadFlipBegin blocked for 10.875ms
2023-07-27 16:40:36.636 21895-21895 System.out gurux.dlms.android I -> 16:40:36.511 7E A8 89 41 03 B0 D7 68 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 02 0F 05 03 00 02 02 0F 06 03 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 01 55 7E
2023-07-27 16:40:36.735 21895-21895 System.out gurux.dlms.android I <- 16:40:36.637 7E A0 07 03 41 31 42 E2 7E
2023-07-27 16:40:37.038 21895-21895 System.out gurux.dlms.android I -> 16:40:36.911 7E A8 89 41 03 B2 C5 4B 03 00 02 04 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 02 03 0F 0A 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F FC 66 7E
2023-07-27 16:40:37.141 21895-21895 System.out gurux.dlms.android I <- 16:40:37.038 7E A0 07 03 41 51 44 81 7E
2023-07-27 16:40:37.438 21895-21895 System.out gurux.dlms.android I -> 16:40:37.322 7E A8 89 41 03 B4 F3 2E 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 80 A2 00 80 FF 02 02 01 02 02 03 0F 01 16 9B D6 7E
2023-07-27 16:40:37.548 21895-21895 System.out gurux.dlms.android I <- 16:40:37.439 7E A0 07 03 41 71 46 A0 7E
2023-07-27 16:40:37.699 21895-21895 System.out gurux.dlms.android I -> 16:40:37.593 7E A0 14 41 03 B6 81 32 01 00 02 03 0F 02 16 01 00 01 00 49 10 7E
2023-07-27 16:40:37.805 21895-21895 System.out gurux.dlms.android I <- 16:40:37.699 7E A0 13 03 41 9A D6 48 E6 E6 00 C0 02 C1 00 00 00 04 FC E9 7E
2023-07-27 16:40:38.113 21895-21895 System.out gurux.dlms.android I -> 16:40:37.993 7E A8 89 41 03 D8 99 87 E6 E7 00 C4 02 C1 01 00 00 00 05 00 81 83 02 04 12 00 01 11 00 09 06 00 80 A2 01 80 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 80 A2 02 80 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 02 04 12 00 03 11 00 09 06 00 80 A2 03 80 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 B9 5B 7E
2023-07-27 16:40:38.224 21895-21895 System.out gurux.dlms.android I <- 16:40:38.113 7E A0 07 03 41 B1 4A 66 7E
2023-07-27 16:40:38.359 21895-21905 ux.dlms.android gurux.dlms.android I Thread[6,tid=21905,WaitingInMainSignalCatcherLoop,Thread*=0xb400007e74a47000,peer=0x13200000,"Signal Catcher"]: reacting to signal 3
2023-07-27 16:40:38.399 21895-21905 ux.dlms.android gurux.dlms.android I Wrote stack traces to tombstoned
2023-07-27 16:40:38.401 21895-21895 System.out gurux.dlms.android I -> 16:40:38.288 7E A0 1A 41 03 DA A9 35 01 00 02 03 0F 03 16 01 00 01 01 02 02 0F 01 03 00 7E A2 7E
2023-07-27 16:40:38.487 21895-21909 ux.dlms.android gurux.dlms.android I ThreadFlipBegin blocked for 11.213ms
2023-07-27 16:40:38.527 21895-21911 System gurux.dlms.android W A resource failed to call close.
2023-07-27 16:40:38.691 21895-21895 System.out gurux.dlms.android I <- 16:40:38.576 7E A0 19 03 41 DC 4A B3 E6 E6 00 C0 01 C1 00 03 00 00 00 01 02 FF 03 00 6C 9C 7E
2023-07-27 16:40:38.878 21895-21895 System.out gurux.dlms.android I -> 16:40:38.761 7E A0 16 41 03 FC A9 E6 E6 E7 00 C4 01 C1 00 02 02 0F 00 16 FF E6 22 7E
2023-07-27 16:40:38.994 21895-21895 System.out gurux.dlms.android I <- 16:40:38.880 7E A0 19 03 41 FE 5A B1 E6 E6 00 C0 01 C1 00 03 00 00 5E 5B 08 FF 03 00 CB 00 7E
2023-07-27 16:40:39.110 21895-21909 ux.dlms.android gurux.dlms.android I ThreadFlipBegin blocked for 12.752ms
2023-07-27 16:40:39.181 21895-21895 System.out gurux.dlms.android I -> 16:40:39.064 7E A0 16 41 03 1E B5 22 E6 E7 00 C4 01 C1 00 02 02 0F 00 16 06 A8 48 7E
2023-07-27 16:40:39.296 21895-21895 System.out gurux.dlms.android I <- 16:40:39.183 7E A0 19 03 41 10 2A BF E6 E6 00 C0 01 C1 00 03 01 00 01 07 00 FF 03 00 16 1B 7E
2023-07-27 16:40:39.483 21895-21895 System.out gurux.dlms.android I -> 16:40:39.366 7E A0 16 41 03 30 C9 EA E6 E7 00 C4 01 C1 00 02 02 0F 00 16 1B CC 83 7E
2023-07-27 16:40:39.600 21895-21895 System.out gurux.dlms.android I <- 16:40:39.485 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 03 01 00 03 07 00 FF 03 00 40 13 7E
2023-07-27 16:40:39.796 21895-21895 System.out gurux.dlms.android I -> 16:40:39.672 7E A0 16 41 03 52 DD AA E6 E7 00 C4 01 C1 00 02 02 0F 00 16 1D FA E6 7E
2023-07-27 16:40:39.917 21895-21895 System.out gurux.dlms.android I <- 16:40:39.797 7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 C1 00 03 01 00 09 07 00 FF 03 00 4E 3A 7E
2023-07-27 16:40:40.106 21895-21895 System.out gurux.dlms.android I -> 16:40:39.989 7E A0 16 41 03 74 E9 EE E6 E7 00 C4 01 C1 00 02 02 0F 00 16 1C 73 F7 7E
2023-07-27 16:40:40.225 21895-21895 System.out gurux.dlms.android I <- 16:40:40.107 7E A0 19 03 41 76 1A B9 E6 E6 00 C0 01 C1 00 03 01 00 01 08 00 FF 03 00 EA 71 7E
2023-07-27 16:40:40.427 21895-21895 System.out gurux.dlms.android I -> 16:40:40.309 7E A0 16 41 03 96 F5 2A E6 E7 00 C4 01 C1 00 02 02 0F 01 16 1E BD 8E 7E
2023-07-27 16:40:40.549 21895-21895 System.out gurux.dlms.android I <- 16:40:40.429 7E A0 19 03 41 98 6A B7 E6 E6 00 C0 01 C1 00 03 01 00 05 08 00 FF 03 00 46 61 7E
2023-07-27 16:40:40.769 21895-21895 System.out gurux.dlms.android I -> 16:40:40.629 7E A0 16 41 03 B8 89 E2 E6 E7 00 C4 01 C1 00 02 02 0F 01 16 20 40 56 7E
2023-07-27 16:40:40.889 21895-21895 System.out gurux.dlms.android I <- 16:40:40.770 7E A0 19 03 41 BA 7A B5 E6 E6 00 C0 01 C1 00 03 01 00 08 08 00 FF 03 00 99 54 7E
2023-07-27 16:40:41.112 21895-21895 System.out gurux.dlms.android I -> 16:40:40.965 7E A0 16 41 03 DA 9D A2 E6 E7 00 C4 01 C1 00 02 02 0F 01 16 20 40 56 7E
2023-07-27 16:40:41.234 21895-21895 System.out gurux.dlms.android I <- 16:40:41.113 7E A0 19 03 41 DC 4A B3 E6 E6 00 C0 01 C1 00 03 01 00 09 08 00 FF 03 00 B2 50 7E
2023-07-27 16:40:41.457 21895-21895 System.out gurux.dlms.android I -> 16:40:41.317 7E A0 16 41 03 FC A9 E6 E6 E7 00 C4 01 C1 00 02 02 0F 01 16 1F 34 9F 7E
2023-07-27 16:40:41.581 21895-21895 System.out gurux.dlms.android I <- 16:40:41.458 7E A0 19 03 41 FE 5A B1 E6 E6 00 C0 01 C1 00 03 01 00 0D 07 00 FF 03 00 E2 2A 7E
2023-07-27 16:40:41.801 21895-21895 System.out gurux.dlms.android I -> 16:40:41.652 7E A0 16 41 03 1E B5 22 E6 E7 00 C4 01 C1 00 02 02 0F FE 16 FF C9 BE 7E
2023-07-27 16:40:41.843 2095-22546 ActivityManager system_server E ANR in gurux.dlms.android
PID: 21895
ErrorId: ee188e74-54aa-441e-a34d-2dc982c4b1cf
Frozen: false
Load: 2.27 / 1.92 / 1.8
----- Output from /proc/pressure/memory -----
some avg10=0.00 avg60=0.00 avg300=0.00 total=60569406
full avg10=0.00 avg60=0.00 avg300=0.00 total=16512545
----- End output from /proc/pressure/memory -----
CPU usage from 53711ms to -1ms ago (2023-07-27 16:39:43.487 to 2023-07-27 16:40:37.198):
