  3. -g Argument In Client Not Working With AttributeIndex Object Type
-g argument in client not working with AttributeIndex Object type
By ashray.a14@gmail.com , 18 November, 2022
Project
gurux.dlms.cpp
Status
Active
Hi.
After I "make" the client CPP. with a successful bin file. I am executing it using the terminal with all arguments.
I am trying -g argument for Attribute index value 2(Containing Objects{...} ) for "BlockLoad profile" in "ProfileGeneric", So when I use
-g (blockLoadProfile_IP):2
Same with other profiles i.,e..,(DailyLoadProfile,InstantaneousProfile,....) containing object type in Attribute index.
I am getting an error at the end of execution i.e..,:
"Error! Index: 2 read failed: Invalid parameter."
in LogFile.txt.
"trace.txt" has RX and TX values, no errors shown in that file.
The same is working well for other index values with -g and also when I use without -g I am able to see the blockLoad profile "entries" and all its values including for objectTypes.
Have been stuck on this for sometime need support..!
Thanks in advance...
Priority
Normal
Category
Support request
3 years 11 months ago
