  3. Unable To Decode The Data Recevied From Meter
Unable to decode the data recevied from Meter
By vibhorkhurana , 16 November, 2022
I am trying to access a Kaifa MA309M meter and with no communication interface provided, I am getting TimeoutException: Failed to receive reply from the device in given time.
But when I am setting the Communication interface as WRAPPER, I am getting some values that I am unable to decode can you help, the options that I am trying are
java -jar gurux.dlms.client.example.java-0.0.1-SNAPSHOT.jar -h <MeterIP> -p 4059 -t Verbose -r ln -c 16 -n "<last 6 digits of meter>" -i WRAPPER -g "0.0.1.0.0.255:1; 0.0.1.0.0.255:2"
Connect using network connection gurux.net.GXNet@1c20c684
Authentication: None
ClientAddress: 0x10
ServerAddress: 0x449b
Standard: DLMS
TX: 17:36:56.329 00 01 00 10 44 9B 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 42 1E 5D FF FF
RX: 17:36:57.012 00 01 44 9B 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 15 03 90 00 07
Proposed conformance:
[GET, GENERAL_PROTECTION, BLOCK_TRANSFER_WITH_ACTION, BLOCK_TRANSFER_WITH_GET_OR_READ, ACCESS, SET, SELECTIVE_ACCESS, ACTION, MULTIPLE_REFERENCES, BLOCK_TRANSFER_WITH_SET_OR_WRITE, DELTA_VALUE_ENCODING]
Negotiated conformance:
[GET, BLOCK_TRANSFER_WITH_GET_OR_READ, SELECTIVE_ACCESS, ACTION]
MaxReceivePDUSize: 912
TX: 17:36:57.018 00 01 00 10 44 9B 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
RX: 17:36:58.120 00 01 44 9B 00 10 03 90 C4 02 C1 00 00 00 00 01 00 82 03 84 01 82 08 24 02 04 12 00 01 11 00 09 06 00 00 15 00 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 15 00 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 2B 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 62 13 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 0C FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 03 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 06 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 02 FF 02 02 01 02 02 03
TX: 17:36:58.121 00 01 00 10 44 9B 00 07 C0 02 C1 00 00 00 01
RX: 17:36:59.416 00 01 44 9B 00 10 03 90 C4 02 C1 00 00 00 00 02 00 82 03 84 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 07 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 09 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 14 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 82 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0C 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0C 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0C 80 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0C 81 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0C 82 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 80 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 34 4B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00
TX: 17:36:59.418 00 01 00 10 44 9B 00 07 C0 02 C1 00 00 00 02
RX: 17:37:00.649 00 01 44 9B 00 10 03 90 C4 02 C1 00 00 00 00 03 00 82 03 84 60 34 7A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 39 5A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 39 5B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 50 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 63 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 63 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 63 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 63 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 63 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 07 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 0A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 0B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 0C FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 0D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 0E FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 0F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 10 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 11 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02
3 years 11 months ago
You have read the object list from the association view and there are a lot of data left to read. There should be 2084 objects. I don't know if this is true, but it's a lot.
You can use DLMS library to parse the COSEM objects.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
